I just started my 95 for the first time and it makes a knocking sound. With a stethoscope it seems to be coming from the water pump. It runs fine other than that.
We took the water pump apart and it seems ok but if you wiggle it back and forth it does have some play. We didn't split the case to see what was going on inside.
A friend of mine who's owned a lot of different bikes says he wouldn't worry about it but he wasn't there. He was the last person to hear it run before I bought it from a mutual friend. He says 2-strokes make noises. I haven't had one in about twenty years but I don't remember any sounding like that...
Should I worry about it or just run it like he says?
Does this sound like a common problem anyone is aware of?
I did a search but didn't find anything.
Water Pump Knock?
tommyd
If you pull the clutch in does it get quieter?
tommyd
No. Tried that after reading about that on here.
I've heard of the KIPS rattle but this is more of a knock. Not as loud as a rod knock. Maybe even a clack... If you grab the water pump impeller and wiggle it in both directions you can get a quieter version of what seems like the same noise. If you take your finger and touch all over the engine while it's running it's definitely strongest at the water pump. I touched the clutch cover and the KIPS cover. It also speeds up with the engine when you give it gas.
How is the drive gear for the water pump lubed? Is it splashed? I wonder if it's just dry from sitting for three years?
If I wasn't about 90 miles from my friends shop where it's at I prolly would just say "F" it and ride it.
GS
Mine makes what sounds like the same noise. KiPS rattle sounds more like a knocking rattle in my beast. If you aren't familiar with the engine, it can 'rattle' your nerves....I've never had another 2S do this like the KDX does!
How much play in the water impeller shaft? Is the noise consistent......with engine speed...in other words does the tempo change with rpm.
For my 2 cents, I'd say ride it and listen/watch for the 1st 2-4 hours......never too far from the truck.
Do you hear the KIPS as well? Cause if you don't also hear the KIPS, then....Eureka!
tommyd
The tempo is consistent with RPM, but it doesn't really get louder or more prevalent like a rod knock.
I don't really hear any other abnormal sounds while wringing it in the shop. If that's a normal sound I might always feel like someone has pulled the pin on a grenade while I'm riding.
I think we're gonna dig into it further. At least then I can check it out and I'll know exactly what I've got. Most of the riding I'll be doing on this bike will be far from home so it will be worth it.
Other than the basics is there anything else I should look at while I'm in there?
- kdxquebec
Hi tom. Do the sound you are talking about is like this?
http://s82.photobucket.com/albums/j259/ ... =kddxx.flv
After a crank bearing rebuilt (4 years ago) the mechanic forgot to install the water pump impeller washer/spacer and the impeller was rubbing on the aluminium case!!
Is it your problem?
Is it your problem?
