Fork bleeder screw size
- cleoent
I would like to purchase a set of either moose or motion pro bleeders for my standard US spec forks. What size do i need? Going online all i see is KX options, are they the same size?
1990 KDX200, 2007 KTM 200XC, 2004 TTR125L
N8Strine
- Mr. Wibbens
No problems here
And my barkbusters give them some protection
- Mr. Wibbens
This would be the trickest way to go
http://www.motionpro.com/motorcycle/too ... _fork_kit/
Here's what I have
http://www.motionpro.com/motorcycle/too ... ___m5x0.8/
Here's what I have
What's the end mill for? To countersink 'em? Give the o-ring something to seat in? If so, then why wouldn't the other 'adapted' set need an end mill?
Who has end mills in their toolbox anyway ('cept for metal smithies).
- Mr. Wibbens
>|QBB<[/url]
O-ring aint gonna contact anything, see where it is?canyncarvr wrote:What's the end mill for? To countersink 'em? Give the o-ring something to seat in? If so, then why wouldn't the other 'adapted' set need an end mill?
Yeah...the end mill is a lot bigger, too.
So what's the end mill for? It's 7/16, the popper is 5/32.
The o-ring is there for looks? It DOES look cute!
KarlP
The o-ring seen in the picture is there to keep the air and oil in the shock until one pushes on the bleeder.
Jeeeez
There must be another o-ring that goes at the top of the threads. See the groove?
The end mill could be used to make a seat for the o-ring that goes at the top of the threads, I guess.
I might be just stirring up trouble..
Jeeeez
'08 KTM200xc
KX100 for the boy
KX100 for the boy
I knew that.... Something has to keep pressure IN the fork.
It didn't occur to me at the time...but I DID know it!
Re: 'The end mill could be used to make a seat for the o-ring that goes at the top of the threads, I guess.'
There is no o-ring on the top. That's what those washers are for (that are shown in the link pic).
The TALL bleeders..that consist of the same poppers threaded into metric thread adapters (no drilling/tapping/milling required), they DO have o-rings on them just as the OEM screws do.
I suppose the mill end could fit the washers on top..but why bother with that?
Maybe you don't need it at all. It DOES say required is what makes me think, well, it's, uh.... required?
I have the bleeders.... always forget about them though.... so they are real useful!
They aren't that useful in USD forks. Not for riding, anyway. The USDs don't build up pressure in them too much. I use them to vent the forks after I strap the bike in on the trailer (and unstrap). I use them to 'tune' the forks during a ride, too, sometimes venting the forks with 'some' compression, sometimes not. Sub-tanks on a budget!
On the RSU forks, they were very useful. About the time the bike started acting like there was NO give in the front-end at ALL (bike would crab trying to turn out of a 2" deep rut! It would NOT climb out!!), venting the forks made it ALL BETTER!
That would happen at least a couple times a ride.
If <you> (insert whomever here) are riding OEM RSU forks and NOT using fork poppers....you are absolutely having a rougher time handling your KDX KYBs than you need to be having! Guaranteed.
RSU: Right Side Up ('conventional' forks, as in OEM KDX. Most KDXs anyway).
As opposed to: USD: Up Side Down (MX bikes, KXs and such).
Of course, any USD rider would say THEIR FORKS are the RIGHT Side Up ones....
'Cept for the likes of wookies that like their earlier model KDX OEM forks.
Capiche?
Capiche?
- Mr. Wibbens
canyncarvr wrote: 'Cept for the likes of wookies that like their earlier model KDX OEM forks.![]()
Capiche?
It's not really that I like them. I just don't think they as bad as everyone says
- Mr. Wibbens
I seem to have more problem with my footpegs hanging up long before my fork lowers do
