1990 KDX200 what should I pay?
- zombiescustoms
New here! and thinking of buying a KDX. I went and looked at a 1990 KDX 200 today, the guy lives 15 min from my house which is nice, the bike is in good shape for its age has had new plastics put on and a new seat cover, new pro tapers and pad, new brake pads and the motor was done by a friend of mine about 10 hours ago, tires are decent bike started right up and it was about 20deg out today, has newer chain and sprockets, larger carb and a high comp piston, he just replaced the water pump and put on a new FMF fatty pipe and silencer and it has a clear regular motorcycle title with no "off road only " restrictions, so I should be able to plate it, I rode it around his yard a bit, it went through a 6 gears fine and pulled real hard, I was very impressed for only being a 200! Any how I really like the bike but have no idea what I should pay for the thing, he is asking $1500 obo but I was going to offer him $900 or so, I really don't want to spend more than $1000 on a bike as I'm not sure how much I want to jump into off road riding with both feet! All you KDX people please chime in!
Also from what I read there are not many differences in the newer KDXs is this true?
Your right on the mark with what you would offer the guy..... The bike is old and chances are you are going to be replacing and greasing allot of bearings in your future!
Larger carb is not good.... and a high compression piston? Are you sure? That is not something that is done.
- m0rie
If its clean, recently rebuilt and runs good i'd say $900-$1000 is a good price for it. If the guy is willing to let you do it i'd put the bike on a stand and check the swingarm and steering head for excessive play which might indicate worn bearings. Pull the pipe and look into the cylinder with a flash light to check the condition of the piston and rings.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- Mr. Wibbens
I'd be leery of the larger carb unless it's really just been bored.
Be nice if it turned out to be a RB'd carb
I paid $900 for my '92 back in '03
But it was on ebay. The auction was ending at 4am and I threw a max bid of $900 at around 2am. I figured the bike would go for about $1,600
- zombiescustoms
dentvet
ZC, folks here will be happy with the fredette name drop. Where are you? i'm guessing nj for some reason. i did a craigslist search midatlantic and kdx prices ranged from $300 ( Otherwise clean older bike needing a piston) to 1600 ( a super clean 2001.) most were under $1000 and 1995 or newer.
Your seller sounds like an enthusiast which is good for the bike's sake but he's trying to get top dollar for it.
- Mr. Wibbens
Just for shits and giggles
PNW KDX Craigslist Prices
92 $900
87 $1000
03 $2900
00 $2100
96 $1200
92 $900
87 $1000
03 $2900
00 $2100
96 $1200
- zombiescustoms
Re: ' there are not many differences in the newer KDXs is this true?'
That is true. But...a '90 is not a 'newer' KDX.
- Mr. Wibbens
The "H" series KDX's might not have as much pull on the bottom as the "E" series does. The fuel capacity is not as much and the forks are a stronger, IMHO
Another case of failing to understand the unclear. It's all muddy water under the bridge at this point 'cuz he got a 2-fiddy..but...
Re: 'there are not many differences in the newer KDXs...'
You can't have a difference between a thing. It takes at least two things, 'eh? How are you going to answer, 'What's the difference between this bike?'
So..I took it all to mean that newer KDXs had little difference between themselves, and the '90 mentioned clearly had nothing even remotely to do with the 'newer' KDXs.
There is indeed little difference between 'newer' (meaning 'A' and 'H' model) KDXs. ..and, the '90 model mentioned obviously has nothing to do with 'newer' KDXs.
Comparing the 'newer' model KDXs to the OLDer model KDXs? Lot'sa difference! Hell...they're not even the same!!
