Rivet gun recommendations
SteveWR450f
Looks like its time to repack my Turbine II S/A silencer. I assume I will need to drill out the rivets and replace. So looks like its time to buy (hopefully?) a cheap rivet gun. Anyone have recommendations and what size stainless rivets I should use.
I thought I saw something about this a few months ago but could not find after searching. Anyway, any input would be appreciated.
Happy holidays!!! Steve
WR sold. Now have 03 and 04 KDX 220s.
KXF 250 forks. RB Carb and Head. FMF rev pipe. Long live the KDX !!!
Aluminum rivets with surfice....
Any hardware store should carry rivet guns....
- Mr. Wibbens
Yeah, just buy a rivet gun and an assortment of rivets
And some high temp sillycone, rivets tend to leak spooge
- skythrasher
- Mr. Wibbens
On the turbine core itself?skythrasher wrote:My turbine core II has bolts on the end toward the engine that you take out and it comes apart. No drilling required.
Most have bolts on either end, but the turbine core is usually held in by rivets
- Colorado Mike
- skythrasher
- skythrasher
- Mr. Wibbens
'Cept it needs to be CLEANEDskythrasher wrote:No need to mess with the "turbine core". It is just the spark arrestor. The packing is in the other end. There is nothing in the spark arrestor to be serviced.
I guess you can just repack but one day you gonna need to clean all that gunk up aint ya??
- skythrasher
- Mr. Wibbens
I dunno what the newer ones are like, but on mine the turbine core is always a big gooey mess
I break it all down and clean everything until I have bare metal
Just makes the repack go much nicer to start with a clean piece
- skythrasher
- Mr. Wibbens
I usually heat the turbine with a propane torch 'til it glows, it'll burn and then smoke for 20 minutes or so
- skythrasher
I bet burning it like that would work pretty well. I have never serviced the spark arrestor portion. I try to keep up with changing the packing and when I do this I always look at the S/A part but have never really felt the need to clean it. Can you tell any difference after cleaning. Mine doesn't seem to get that spooged up.
- Mr. Wibbens
It's just a lot nicer having it all clean
Seems if you get just a dab of spooge on your hand that **** ends up on everything in the shop
Maybe yours will turn out different...but my disassembly of a TCII on an 'H' KDX (same for 'A' models as yours) ruined it.
Yeah..you can take the rivet out/off easy enough. When it became obvious that the spark arrestor part wasn't going to come out without damage, I DID get it out..but only with a LOT of damage. By 'damage' I mean it was toast...no good no more...beyond repair...all bent to hell.
I've 'cleaned' mine with Yamaha CCC, and some other solvents. That don't work too good, either. You can dump a lot of fluid in there..and it don't wanna come out.
Maybe soak the whole thing (the arrestor end) in a gallon of Berryman's......
I suppose a REAL torch (meaning something other than propane) would cook off something..and maybe turn the aluminium cannister into a puddle of shiny stuff.
Or...just leave it alone!
If THIS is the point:
..you don't mess with the rivets..just the allen button heads on the other end.Looks like its time to repack my Turbine II S/A silencer.
