Piston size?
hoodoo
Piston size?
I have a 2000 KDX 200. I have owned it for 18 months. Pulled the cylinder off, cleaned the kips. Everything looked pretty good. There are marks in the cyclinder walls but no grooves or gouges, slight brown oil varnish on the cylinder walls. It cleaned up pretty good. Machinist at work is going to measure it tomorow.
The piston is a "C". Does this mean its been replaced? When the bike was brand new in 2000 wouldnt it start out with an "A" piston in it?
I believe the letter designations start with "A" then "B", "C", "D"for stock pistons then you would have to go with oversize pistons. I have a Weisco piston in hand but want to make sure the thing is the correct size for my cylinder. Weisco only makes one size for the KDX as I understand. Proex sells the incremental sizes.
When I bought the bike I did all usual checks, swingarm, replaced the wheel bearings front and back. Replaced the chain and sprockets and rear tire. Put 40 kg xr400 springs in (what a difference) Run a FMF woods pipe &TC silencer, Boyeson 607's reeds(no DF3 yet),Carb is out for RB mods at the moment. Have Protaper SE cr highbend bars with tusk hand guards.
I love this bike. The guys I ride with all have late model CR 250s and I pretty much own them in everything but the sand, (which I hate, only ridden it once), woods and high desert for me.
Tonight I dropped the front end out and the lower bearing is wasted....its the one thing I neglected to do in the past year, glad I decided to look cause its a rusty piece of crap. I will cut it off and replace top and bottom bearings, I wonder if I can get those Hihat bearings at a bearing supply house instead of paying Kawi prices?
By the way...love this site.
John Cena
- KDXer
I ended up getting it cheaper from a dealer than CBC bearing co. It was about $35AU $5 cheaper than the bearing shop.
EDIT... I thought the bore size on the 200 was 66.00mm ???? I was unaware that something with an OD of 66.00mm would fit an ID of 66.00mm.
- fuzzy
I doubt your machinist can measure the cyl acccurately enough to get down to the differences between A-D. These are used to make up for the VERY slight wear in the nikasil plating between top-ends. If the plating looks OK, then 'hone' it lightly w/ some scotch-brite, and then put a 'D' in it. Next time, E. These again are VERY slight. You can run an A in a cyl worn out enough for a F...You can run an F in a brand new cyl(wiseco)...When the clearance is tighter, a slight increase in power will be had. Warming the bike to full temp before riding it is imparitive when using tight clearances.
Wiseco's piston is probably for a 66mm bore, but isn't really specifying the actual diameter of the piston. It will be closest to a D or really more like an F....
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
- lankytim
Your right Tim...
hoodoo: re;'The piston is a "C". Does this mean its been replaced?'
No. It does not mean that.
re: 'wouldnt it start out with an "A" piston in it?
No.
...I'm just agreeing with the rest of the folks.
Wiseco indeed makes one piston for the 200. Pro-x indeed has different sizes grouped by the alpha designation. You cannot specify which alpha if you order from Kawi. You will likely get a 'B'..but maybe not.
The difference advertised is .01mm which equals approximately 1/2 of one thousandth of an inch.
That measurement (.0005") isn't a huge matter in babbit bearing clearances (rods/mains in most autos)....it matters less in piston-to-cylinder clearance.
Consider there is only one ring size available for all of the alpha/different pistons.
But...might as well do it right if you're doing it.
No.
hoodoo
fuzzy wrote: Warming the bike to full temp before riding it is imparitive when using tight clearances.
When using these forged pistons... always warm fully before putting under load or else you MAY get some piston slap and will wear the cylinder. I've heard 'em rattle in the cylinders before warm. Avoid a cold seizure....
Here's another piston question:
Seeing how Weisco's pistons are forged and ultra-lite, are you losing the flywheel effect of the heavier cast Pro-X piston? Is this a nominal amount or does it make a difference?
Hmmmmm......
IdahoCharley
Is the loss in flywheel weight effect more than made up in allowing the bike to rev quicker due to less rotating mass? More smiles per mile?
Light weight fender MX fender plus RD sticker plus Wiesco piston, plus KX front end equals = ?????
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- KDXer
IdahoCharley wrote:MX fender plus RD sticker plus Wiesco piston, plus KX front end equals = ?????
- fuzzy
Tim, that C on your cyl means that Kawi put a C in it at the factory. They must plate/hone them, then measure for piston fitment and install what works. The differences in these pistons is VERY small. When you rebuilt, you should've gone to a 'D.' The next time 'E', etc. They do this so you don't have to have a million dollar machine measure your bore between rebuilds.
Inda, you know this to be the case. You just went through this, and your 'B' cyl took an 'F' piston....Right? And you only knew this due to the highly sophisticated equipment you had available.
The difference is sooooo small (.0005"). You can take a bike off the showroom floor, never run, and put a 'F' in it. This will be clearance close to a Wiseco....Maybe this is why some people call them siezeco. They are just trying to actually get you the extra power you're paying for when you buy their stuff. Warming up is critical. The piston really doesn't slap around, but will expand (warm up)quicker than the bore itself resulting in a piston going 5000+ RPM that now doen'st fit in the bore anymore....This is the defenition of cold siezure. Running the slimmest piston clearance possible will make the most power, but you're talking fractions of 1hp here....
- dave04kdx
Re: CC's comment on "only one size rings for all the different pistons". You are so right ! It's always a good idea to check ring end gap. The last time I did the top end on my 88 one ring had an end gap that was tighter than the manual spec. I had to file the ring to get the ring gap correct.
