A Short BOIL OVER.....
Green Hornet
Post by Green Hornet »
When riding this morning, the Old Girl had a Short Boil Over after coming up a Snotty Hill. I was Clutching her in 2nd, so I would get minimal Wheel Spin, but had to drop to 1st to anyway. Every time I got going up the hill a Branch would Grab my Right Boot & YANK IT OFF!! Then the Left Boot would get YANKED OFF!! Then the RIGHT AGAIN!!!! I probably lost about 1/4 or so of coolant & I noticed the 220 did not seem as peppy. I believe the Clutch was Slipping after the Boil Over. Could the Clutch Slipping be caused by a Slightly Hotter Engine????? It could be time for a Clutch Rebuild also.........
Any Thoughts??
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
MX500
Post by MX500 »
If your clutch is slipping, replace it. I've never had a clutch slip after boiling over. You ought to try adding some water wetter or try using the Evans coolant. It boils at 370 degrees, your engine would have seized by that point.
http://www.evanscooling.com/main27.htm
Green Hornet
Anyone use the TUSK CLUTCH KIT??If so, have you Experienced Clutch Slippage??? Last year TUSK acknowledged they had a BAD BATCH of FRICTION PLATES.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
fuzzy
Post by fuzzy »
I used them in my WR....Grab fine and smooth. Mine must've been a bad batch though 'cause the tangs were too wide for the basket, and I had to hand fit them with a file. I could never ding tusk as it as a hinson basket, but should be OEM spec.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
Green Hornet
Speaking of HINSON. Anyone know where I can get a Basket???????
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Fredette... eBay... only 2 options I can think of.
