Radiator Fluid Change
allinson
Post by allinson »
It is time to drain my radiator fluid. A couple of questions?
1. Do I drain the radiator and the plug by the impeller?
2. My KTM has a bleeder to get the air out. Does the KDX has one as well?
scheckaet
Post by scheckaet »
yep they do have a bleeder to get the air out on top of the head.
Plug by the impeler? Don't remember doing that last time I replaced the fluid.
allinson
Post by allinson »
I am not sure, but I thought that I seen a drain hole down there?
When you open the bleeder, do you have the bike running?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yup
allinson
Post by allinson »
Is that a yuper on both the bleeder while running and the drain hole?
Jeb
Post by Jeb »
I don't open the bleeder while running. After you've poured in coolant to achieve the needed level, slowly open the bleeder and you'll usually hear it make a slight hiss and then it'll start to leak. . .
you'll need to add a little more coolant.
Start it up for the first time with the rad cap off. Rev it (a little) and you'll see air bubbles. After a few minutes the bubbles will cease, put the cap back on.
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yup was to the bleeder on the head. I always crack it when the bike is running. As far as flushing the entire system... I have never had to do it, I have only pulled the lowest hose and drain so I could get the cylinder off without getting coolant in the lower end.
