tope end replacement
midlifemoto
Post by midlifemoto »
when or what are the tell tale signs this needs to be done? I have a 2006 KDX 200 with about a dozen outings on it. It runs strong but perhaps just a tad off from when I got it. Do you do a compression test? On it's first top end is it usually just rings? I know there's no one easy answer as there are many variables...just trying to get a consensus on when ya'll decided to do your first top end and what led to that decision. thanks!
I spent most of my money on women and beer, the rest I just wasted
2006 KDX 200
2007 Harley Softail Custom
2004 Harley Heritage Special (was owned by Evel Knievel)
2006 CRF100 (sons)
2006 CRF 150 (girlfriends)
1978 RM250
1979 CR 125 Elsinore
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Wait about 4 years then ask again... :wink:
midlifemoto
are they really that durable?
2006 KDX 200
2006 CRF100 (sons)
1978 RM250
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Yes....
2001kdx
Post by 2001kdx »
Depends on the rider. The weekend warrior might go 4 years, and the avid woods racer might go just one season. Where are you at?
midlifemoto
I run that bike pretty hard in wide open areas...not much tight techno chuggin' along
2006 KDX 200
2006 CRF100 (sons)
1978 RM250
scheckaet
Post by scheckaet »
That's really nothing as long as your jetting is somewhat close to correct
midlifemoto
ok, thanks...I treat it like a cheap prom date...rode hard and put away wet....most of my riding is of the motocross nature, but I'm sure after hearing from folks that I can get thru 2009 season at least before putting new rings in it
2006 KDX 200
2006 CRF100 (sons)
1978 RM250
Jeb
Post by Jeb »
If you run it hard and often you might consider replacing the rings every season . . . gives you a chance to check tolerances and keep the KIPs in good shape.
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
Mr. Wibbens
Post by Mr. Wibbens »
I last did my top end in 2003
It still pulls all 275lbs of me (without gear) up anything little Carvr can go up!
skipro3
Post by skipro3 »
That is true! I've seen him without gear. And Carvr is little.
Jerry
Mr. Wibbens
>|QBB<[/url]
skipro3 wrote:That is true! I've seen him without gear. And Carvr is little.
Come to think of it you prolly seen my GEAR! :shock:
kicknrocks
Post by kicknrocks »
I might be mistaken, but doesn't midlife want to get the grenade out of there?
'01 KDX 220
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That's only 220's.... he has a 200.
Cturbo
Post by Cturbo »
I used to check for compresion and after 12 years waiting for a change I open up the top end. Everything was within specifications but I put a new Wiseco anyway. I gained a little bottom end probably because the Wiseco is lighter.
1992 KDX 200
2004 KLX 110
2006 SMR 510
skipro3
Post by skipro3 »
I honestly think most trail bike riders change out their pistons/rings way too often, more than necessary. These motors are either designed for the MX world, which we are never going to abuse a motor like, or they are way over built for the riding style, which the KDX motor is for sure. I think it's much more likely to wear the cylinder lining away before the piston is shot.
I pull my pipe and look up in the exhaust port to examine the side of the piston and the back of the cylinder. If they show any wear, I tear down the top end. If they look good, then probably the whole piston and bore are going to look good. Just what I do........
Jerry
