torquing cylinder nuts
rick albert
hey guys.........just wonding if theres a trick to torquing the cylinder nuts i looked on the special tool site,but found nothing ..... i got a couple ideas how i might go about it....one being by moding a boxend wrench so you can use your torque wrench on it .......(i think that will be better then a crowsfoot):rolleyes:
JUST RIDE !!!
To be honest... I torque by feel on those... never a problem yet!
- Colorado Mike
A crow's foot never worked for me. Motion Pro makes a box end wrench that works well. It has a 12mm on one end, a 14mm on the other, in the middle is a 3/8" drive hole for the torque wrench. They include a formula for calculating the changed torque value, but if you just rotate the wrench to be 90° to the torque wrench shaft, you don't need to change anything.
Mike
'04 KDX220
'04 KDX220
Motion Pro's tool looks kinda like this.........
By feel is fine...but that low a torque can sneak up on your calibrated elbow....
- skythrasher
If you want to mod a box end motion pro's website has the directions for the tool above. It gives the dimensions and multiplication factors. http://www.motionpro.com/images/documents/08-0134.pdf
rick albert
