Lower Bearing Play
- Jeb
Lower Bearing Play
I couldn't find the recommended max lower bearing play in the online manual . . . anybody ?
Side to side?
That's not generally a wear factor..it's usually quite a bit...and doesn't generally matter.
Up and down?
If you can feel it...it's way bad.
imo and completely lacking any notable references.
Up and down?
KarlP
I'm with CC on that. Any actual up down play and it's long gone, it'll beat the lube out in no time. Besides, if you can feel a bit of play by hand imagine how much there really is under power at the rear wheel?
'Course, you did not say up down, did you.
CC had what looked like a neat solution to that lower bearings weaknesses, if you'd care to search.
'08 KTM200xc
KX100 for the boy
KX100 for the boy
Uh oh...we're not talking about a connecting rod?
Are we?
Lower shock bearing? Some game in Austrailia (sic).
I think I've fallen (probably down the stairs, even)...and I know I can't reach my beer!!!
WHAT ARE WE TALKING ABOUT??
Are we?
- Jeb
There probably is a specification, but I don't know what it is.
If it was a babbitt type bearing, it would matter because excessive side play drops oil pressure..sometimes to the point of bearing failure.
...but it isn't...so don't!
- Jeb
- Cturbo
