canyncarvr wrote:
The Boyesens are very straightforward install-wise. It would be hard to mess them up.
I vote for erased memory banks!
I checked the silencer (w/ compressed air, it's not blocked). Rechecked everything else. I checked the KIPS gears, I can see it move at raised rpms under the left side cover. My manual refers to the RIGHT side as having the o-ring and groove, I believe this is correct and therefore I put the KIPS together correctly.
Rode 50 miles at Browns Camp (1500-2100 feet elevation).
I learnt several things:
1) I'm too clueless for the RB Carb. I should have just put an FMF pipe on and rejetted. I'd read all about this killer mod but I'd never touched the jetting on the old bike, it just worked. Noones fault but mine.
2) Carb: needs attention. Either the float level is wrong or the valve is sticking, or the pilot is wrong. The bike would constantly stall whenever (going down hill) I'd slow down. This was frustrating. Adjusting the air screw made no difference to this.
I upped the idle speed, it still would stall, If I was close to a flat, I'd just coast. Then use wide-open-throttle to kick it into life (usually wouldn't start any other way). It would get going and settle into a fast idle (too high as I'd raised the idle speed).
Probably gained 800' during the ride and the idle speed would vary widely with elevation.
4) I tried doing what Ron suggested and start by _just_ looking for the sweet spot in neutral via blipping the throttle, making 1/16th adjustments from his start point, I couldn't tell any difference. If I screwed it all the way, I could and the idle speed would drop, but it didn't seem sensitive to small adjustments. Need to play more.
5) I hit reserve, or I think I did. Going up a steep hill but the motor starting racing like crazy which is the opposite of what I expected. Almost topped out in rpms but with no throttle. I killed it. Couldn't start it. Switched to reserve and jump started it down the hill at which point it seemed ok again.
6) I should look at gearing. Stock 13/47 currently. I'd never liked 1st gear, even in the stock configuration. Too abrupt in 1st. Friend rode it yesterday and felt same way, very hard to be up on the pegs in 1st as the power delivery was so abrupt. Easier to control sitting or just off the seat. 2nd and 3rd are much smoother and power is more controllable even though there is more power in those gears.
Tops out way early in 1st. Another guy had a 200 with a 240 kit, 14 tooth front sprocket I think (couldn't see a marking on the rear -- he's going to check for me) and his would rev out way way higher in 1st and the power was more controllable.
Mine feels like it's either bogging at the top of 1st gear, or totally gearing limited.
7) When we got back to camp, I used a stick to measure gas levels. I was 1 3/4" lower than the KDX200 with the 240 kit and he was riding much harder than I was.
Plug seems oil wet to me indicating I'm running too rich. Stalling would seem to be pilot, not sure if the main is whats causing it to bog out in 1st or if it's gearing. It's a lot better in 2nd and 3rd but maybe I'm just not reaching the equivalent point.
