Easier Clutch?
- TopperHarley
Easier Clutch?
I recall reading somewhere(not sure if it was here or not) that someone made their clutch easier to pull be modifying/ extending the fulcrum on the clutch actuating rod. Has anyone tried this? if so, how much did you extend it? Extending the lever part of the rod would make it easier to pull but it would require more throw to get it to disengage. I would like to hear from someone that it works before I go cutting and welding on one of mine.
I'm not ready for the auto clutch but it would be nice to make it a little easier. I have a Moose easy-pull gadget but I cant tell much of a difference with it.
If you run into Heidi, have her look me up in her little black book and give me a call.
Im feelin a little wild today.
http://stores.shop.ebay.com/GATEWAY2-STROKE
2005 KDX220 mine
2003 KDX220 mine(under construction)
1998 KDX220 1/2 Brother-in-laws, soon his own
2005 KDX220 mine
Start with dumbells at about 15# work your way up to 50# curl, curl , curl.... and don't look back! ![Laugh :lol:](./images/smilies/b_grind1.gif)
- TopperHarley
but that would give me some definition on my "girly 220 arms." ![Wink :wink:](./images/smilies/icon_wink.gif)
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
I'm a lefty also....but I need to use both. ![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
2005 KDX220 mine
2005 KDX220 mine
Uh...I'm a lefty too!
I think Ski is and proly more on here....
When I curl... I start with my hand partially open and pointing at the ground so I get my hand, forearms and biceps...![Wink :wink:](./images/smilies/icon_wink.gif)
![Embarassed :oops:](./images/smilies/icon_redface.gif)
- TopperHarley
a wrist curl ![Wink :wink:](./images/smilies/icon_wink.gif)
2005 KDX220 mine
2005 KDX220 mine
- skipro3
- radonc73
- TopperHarley
Hey Vince,
why not do a poll of who is Left and who is Wrong handed.![Laugh :lol:](./images/smilies/b_grind1.gif)
2005 KDX220 mine
2005 KDX220 mine
Good idea! ![Super :supz:](./images/smilies/icon_super.gif)
- TopperHarley
They say that left handed people are above average intelligence.
We have to be in order to survive in a right handed world.
I work with right handed tools all the time with no problems.
could you imagine what would happen if all the right handed carpenters woke up one day and had to do their jobs using circular saws made for left handed people.
be lots of short fingered right handed carpenters out there.![Laugh :lol:](./images/smilies/b_grind1.gif)
2005 KDX220 mine
2005 KDX220 mine
how bout goin hydraulic?
06 kdx 200 - mine
06 kdx 200 - dads
my gallery http://kdxrider.net/forums/modules.php? ... _album.php
06 kdx 200 - dads
It's been done here. I didn't search for it..and don't recall who for sure.
You don't get something for nothing. The longer the arm, the less clutch pack release.
Given the same puller and all.....
Check a couple other things. How much slop is in the clutch cover hole? ANY movement there means less movement to the actuator. Have it bushed if it's sloppy.
Check your lever for wear..at the hinge and the cable slug.
What's the shim setup on your clutch pack? Check to be sure the arm is installed properly. It should move through a 90º line during actuation. As the clutch pack wears, more of a shim may be required to get that measurement.
Replace your clutch cable. Consider one'a those hot-rod longitudinally wrapped jobs (if they make one for the KDX).
Not all levers have the same pull...OR the same cable movement.
If the internet wasn't such a PIG on Sunday night...I'd look at RockyMtn to see if they sell such a setup. Probably. I don't recall the name of the good one. Haven't seen it in a few years.
- krazyinski
DONE IT! I AM HYDRAULIC!!!
Works great no fade, one finger pull, same action every time and it feathers nice. It took one ride on my Buds KTM and I had it on order, best thing is it never changes. Half the clutch fade I had was cable related. When the going gets tight and technical you never think about your finger or arm pump. Only thing that can beat it is auto clutch. Magura
I just don't get it... I never have any problems. ![Neutral :neutral:](./images/smilies/icon_neutral.gif)
Me neither.
Glad you're happy with it, though!!
- TopperHarley
I have some carpel tunnel issues in my left hand. Western medicine was very excited and anxious to cut on me when I was diagnosed VIA nerve induction test. I told them to get lost. Went to a homeopathic doctor and was advised to take some supplements.
Condition has gotten much better. Seems to be going away. I did 25 miles of some extremely technical stuff today and had no problems at all.
Rain cut our ride short.![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
2005 KDX220 mine
2005 KDX220 mine
Even though my KTM has a hydraulic clutch I really don't see any real advantages with it - yes there is no on the fly cable adjustments while riding - but other than that there is more maintenance. I change my hydraulic clutch fluid twice a season which takes 10-15 minutes if everything goes well and 30-45 minutes if there is an air pocket somewhere. Periodically the slave cylinder o-ring needs to be replaced. I do worry a little more about crashes pulling the clutch line loose or breaking the master cylinder.
With a cable operated clutch I would hook up the cable luber and flush the cable with silicone maybe twice a season. (3-5 minutes) A clutch lever with a large on the fly cable adjuster was just second nature to me on my previous KTM. The KDX could certainly have a on-the-fly cable adjuster added if you find yourself needing to adjust cable slack repetitively on trail rides. Cables are also cheap to replace and check the wear of - while the opposite is true for the hydraulic system.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
