Engine output shaft seal
TopperHarley
Post by TopperHarley »
I seem to be loosing a small amount of oil from my output shaft on my 2002 220R. Its not too bad but I want to fix it. How easy is it to change the output shaft seal. I am assuming it can be done w/out cracking the case, I hope.
If you run into Heidi, have her look me up in her little black book and give me a call.
Im feelin a little wild today.
http://stores.shop.ebay.com/GATEWAY2-STROKE
2005 KDX220 mine
2003 KDX220 mine(under construction)
1998 KDX220 1/2 Brother-in-laws, soon his own
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
You talking behind the countersprocket? No case splitting needed! Just pick out with a scribe.... clean well.... replace.
m0rie
Post by m0rie »
Depending on the condition of the collar it will have to be replaced as well.
1989 KDX 200
2007 TTR-50E
kawagumby
Been thanked: 3 times
Post by kawagumby »
Sometimes drilling a small hole and screwing a sheet metal screw (or two) into the seal will give you a gripping surface to pull it out with, reducing the possibility of damaging the case seal surfaces. Also, if I recall correctly, the seal wear point usually isn't exactly centered on the collar, so you can reverse the collar for some extended use. (OK, I'm a cheap bstd...oh wait, no, I'm responsibly conserving the world's resources to help reduce global warming!). :supz:
quailchaser
Post by quailchaser »
I'd be surprised if it's the seal in the case or the collar on an '02. Usually it is the O-rings behind the collar.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
kawagumby
Post by kawagumby »
quailchaser wrote:I'd be surprised if it's the seal in the case or the collar on an '02. Usually it is the O-rings behind the collar.
Could be. A bad O-ring will leak oil right through the spacer well beyond the seal. The seal will leak, well, at the seal. Clean and check.
TopperHarley
I pulled the collar out and it has a step in it where it fits over the oring. does not appear to be reversable. Perhaps it was on pre 95 models. I like the drilling and screw method for removal. Guess I better order an oring and collar also.
2005 KDX220 mine
