hi im thinking of getting some tag cr double hi t2( fatbars) onto my bike,
i already have fat bars with adapters not the tag ones in the link, but pretty much the same, if you dont know click the link...
( http://www.tagmetals.us/mx/productdetai ... =barmounts )
so im just lookin for more hight (as im 6'5 with out boots...)
but will my cables be long enough? can you even get longer cables? (im thinking clutch could be a problem)
thanks
high bars and cable length
alistair
06 kdx 200 - mine
06 kdx 200 - dads
my gallery http://kdxrider.net/forums/modules.php? ... _album.php
06 kdx 200 - dads
- skipro3
- paceyman
- KDXer
I have the highest bend bars TAG sells. ATV minis or something like that. My clutch cable is at it limit (full lock left) and is slowly wearing a groove in the steering neck and wearing away the plastic sheath. I will have to check the routing. With bar risers aswell I would think your clutch cable will be too short FOR SURE.
alistair
sorry for taking ages to reply had sum family matters to help out with...
anyway i guess ill just stick with what i got,,is there anyway to move the bars forward?(other than just spinning the mounts around,im pretty sure there in the forwrds position already.)
i have stock forks and clamps.
thanks
thanks
06 kdx 200 - mine
06 kdx 200 - dads
06 kdx 200 - dads
- krazyinski
run some tag bar clamps and CR CR High MINI bars they bolt on with no problem. They move the grip position forward and up and takes your hands off your knees.
