1995 KDX200 Shock Internals Pictures
Has thanked: 153 times
Been thanked: 38 times
Just in case anyone is interested, here are some pictures of the internal components of a 1995 KDX200 shock. These are from when I worked on IndaWoods' shock recently. 1989 - 2005 KDX200 / KDX220 shocks look similar internally. 1988 and older shocks look a good bit different.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Ah... what a beautiful shock! :razz:
canyncarvr
Post by canyncarvr »
Looks like it needs to be revalved to me.
:wink:
Too many flat washer thingys...
skipro3
Post by skipro3 »
That's not the stock valve, is it?
Jerry
Hi, skipro3. Yes, that is the stock piston. That is the top view (rebound side) in each picture.
EDIT: skipro3, here are a couple of pictures of the stock piston from a 1989 KDX200 shock. The first picture is the rebound side. The second picture is the compression side.
As best I can remember, the 1989 and 1995 pistons look the same. The stacks are different, but the pistons are the same.
m0rie
Post by m0rie »
Jason - Did you note (write down) the differences in the shim stack for the 95+ shocks vs the 89-94 shim stack?
-Maurice
1989 KDX 200
2007 TTR-50E
I think I did. I would suggest you just check out the http://www.suspensionnetwork.com to compare them. He has valving listed for various year model KDX's. It would be a lot quicker than me trying to find them. :grin:
