My Clutch
MaD_SheF
My Clutch
hey all just a question:
when i was preparing to loob the chain on my 220 somthing kinda funny happened..
i had the bike jacked up and started the bike. i then pulled the clutch and dropped the bike into first gear. as soon as i putt my bike into to first gear the back wheel began to spin even with the clutch in. is this because the clutch is not being fully activated? if so how could i fix it? or is the bike in need of a new clutch all together?
"I didnt quit riding becuase I got old, I got old becuase I quit riding." Best quote I have ever heard haha.
That's what they do....
- Jeb
MaD_SheF
- fuzzy
What you're describing is called clutch drag. The KDX is famous for it. When the bike is on the ground it probably lurches, and idle drops when you put it in gear? Well, at that point the clutch is actually slipping ever so slightly. When you pick the bike up as in your example you see it engage. It's a tough wet clutch, and is nothing to worry about. What it boils down to is the actuating assembly for the clutch is a bad design.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
- wanaride
No one else said anything so maybe everyone does it like that, but...
Running the bike on a stand to lube the chain? Wow, that sounds like an accident waiting to happen.
Why not just lean the bike over while on the kickstand and spin the tire by hand??
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
2006 KTM 250XCW
2003 KDX200
2006 CRF70
- radonc73
Enough safe and sane we NEED more danger here!!
I wouldn't lube the chain like that but I don't see it harming anything on the bike and unless you are careless you will keep all your fingers.
Riding is living everything else, is just waiting.
Master of the casual pace
83 KDX 200
93 KDX 250
84 YTM 225 DX 3-WHEELER
83 KDX 200
93 KDX 250
MaD_SheF
- Jeb
I start my bike, and with chain lube can in hand - pointed in the general direction of the chain - I tilt the rear wheel off the ground via the kickstand. I drop her in first and lube away, works great!! I think it's safer than spinning the rear wheel 'cause I don't have to touch anything that's spinning.
What kind'a bike does your Dad have?
I'm curious what bike has NO clutch drag.....
Well...BMWs with dry clutches I suppose don't drag much...
A BTW...this chain spraying event (motor driven or not) DOES take place on the INside of the chain, right?
NOT on the OUTside of the chain, say, on the back of the rear sprocket?
Re: '..why would one lube the outside of the chain???'
Because that is the easiest access. Doesn't do much good...but it's easy!
But...centrifigal force is not your friend in such a case.
A chain should be lubricated on the inner circumference. Then..centrifigal force IS your friend!!
- Jeb
I direct the spray down on top of the chain - to the inside of the chain walls - where the chain is returning to the C/S as it's spinning, giving it a good going over to make sure it works it way to the insides of both chain walls. Perhaps a bit wasteful but it seems to work best I can tell. And it's quick and easy.
You might want to put that one in a museum. Probably ain't another KDX like it in the world.MaD_SheF wrote:My dad has a kdx 220 just like mine same year and everthing
Not that I doubt you or anything...but I'd have to see it to believe it.
OK...I guess I doubt it a little bit....
