Slightly bent front KX rotor
Picked up a used front KX 125 wheel for a spare and the brake disc has a lil wow in it. I hate to replace it without trying to straighten it first, anyone have any suggestions?
2000 KDX 200 97 KX 125 Front End
1996 CR 250
03 RM 65 2000 YZ 80
1996 CR 250
03 RM 65 2000 YZ 80
- m0rie
Bend it back into shape with a cresent wrench. Work your way around the rotor tweaking it a little at a time.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Rotors are hard to straighten... then when you crack it... it's no good... can throw ya too!
Be safe and just getcha a new one!
You can straighten them but not likely to be 100%. I've used 4X4 to set the disc on then smacked the appropiate area with a 2-3 lb mallet. Check with a straight edge and add additional blows as necessary.
You can also clamp the disk in a vise (soft jaw or lined with wood) and smack it in the appropriate area check and repeat.
If yours is badly bent - more than very slightly bent - Indawoods has the best answer.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
yeah i think that you should probably take it to an engineeringplace or a sheet metal worker and they will have the answer for you. that way you know that if it does break then it wont be your fault. but on a serious note they have recently done one for me which was pretty bad and it came back like new, they even polished it for me. i couldnt tell if it had ever had a bend in it
![>|<](./images/smilies/quotespacer.gif)
![Go back to the original posting. >QBB<](./images/smilies/quotebackarrow.gif)
I'm thinking that in the States 'engineering place' would be called a machine shop.steve baker wrote:yeah i think that you should probably take it to an engineeringplace or a sheet metal worker and they will have the answer for you. ......
FWIW - Typical sheetmetal workers in the States don't work on anything thicker than about 12-14 guage material based upon my experiences. (Use to design ventilation systems for various processes)
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Tried to re-bend mine...No Go....I bought a MOOSE HD Front Rotor..If you can bend this type, your wheel & Forks will bend with it...The moose is made like the OEN Rear, but GOLD COLORED
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- skipro3
If you do replace it, may I suggest using an over sized rotor? I found mine to really aid in 1 or 2 finger stopping power. (Along with a stainless steel brake line). they are easy to install and despite what others may say, they don't seem to get bent any more than regular rotors just because they are a little larger diameter.
Jerry
