hey guys i blew up my kdx 250 recently so i went and bought another. this bike is exactly the same except it is oil injected. i bought this other bike as i discovered cracks in the engine port holes. i got this other barrel and got it honed. all was good and ready to go back together, new rings, new circlips, new base gasket, new head gasket, etc. it went to put the little end bearing in the little end of the conrod. but it wouldnt fit, i dicovered that the two bike had different sized little end holes. i couldnt believe it, the are bothe the same same year. the only two diifferences that wouldnt matter much is that one is oil injected and one is not and also one is made in march 1991 and the other is made in november 1991. please help me out a bit
[/b]
two identical bikes different sized little end hole
That's going to make a difference on the wristpin and piston too probably!
You should mic the con rod hole and match up the bearing. The US never had a injected motor so I have never had to deal with one but you better make sure you get the right parts of you maiden voyage may be the last.
I know you should mix the fuel yourself though and do not trust the injection.... many Yamaha Enduro's failed her in the states once they had some age on them....
