Nelly wrote:Got it! Thanks for clearing up my state of confusion!
Re: 'right when the speed came up and the suspension started to "plane out", the motor would hit pretty hard. Distracting.'
Classic 'C' taper response.
I could look it up I guess...but what is the 'Q' db rating? I wouldn't trust any piece whose primary benefit is to be quiet.
I've been running an OEM 'muffler' for a few months. It's little quieter than my PC S/A was..2-3db actually..but I like the downward/outward turned snout. The 'old style' bell tip of the PC made a mess of spatter with the airstriker carb. The OEM unit does a LOT less of that. It runs just fine! I'll probably pick up another aftermarket here pretty quick..but I'm not in any hurry.
It IS a good thing to know that the OEM unit can plug up.
I wonder what a can of YCCC would do.........(Yammy combustion chamber cleaner).
Back to other things....see what an -EG gapped to a loose .028" does. And...DO you have an aftermarket lighting coil?
DO try a DEK..probably with the existing 150 and try a 152.
Off the FmF-Q. Run a can of YCCC through the OEM S/A. Plug it up and let it sit overnight maybe.
I'm assuming YCCC is liquid at one atmosphere pressure? I don't know that.
Heck...pour some of your Berryman's carb-cleaner gallon in it. Let IT sit!
I got money to burn...
Buy a DF3 reed block........
