trans oil quantity
kdxluvr
trans oil quantity
Post by kdxluvr »
how many ounces of trans oil does an 03 kdx220 hold?is the site window correct?mine seems full at 18 ounces.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Put the entire quart in there and call it good... helps quiet down the clutch.... doesn't hurt a thing on a KDX.
kdxluvr
Post by kdxluvr »
thanks inda.been using 25 ounces.that puts it well over the sight glass.
2001kdx
Post by 2001kdx »
650 ml I believe or somewhere near there. Like he said, a little extra keeps noise down.
canyncarvr
Post by canyncarvr »
What 'seems full' and what you see in the sight glass are related...neither of them tell you much.
Use a couple ounces of your quart to flush out the case after draining. Use the balance IN the case.
'H' model spec is 700ml.
A quart is 946ml.
