Which pipe do I have?
Motodeficient
My 98 KDX220 came with an FMF Burly pipe... which I know is the earlier version of the gnarly. I'm not sure if its the woods or rev pipe? Or was there two versions of the "Burly"? I forgot to write down the stame on the back of the upper mounting tab, but I do remember it ended with the number 30. I think it was either B 30 or K30. What kind of pipe do I have?
Motodeficient
- Jeb
IdahoCharley
2001kdx is correct - The K30 model number reflects the pattern/design cone build configuration: The designation 'Burly' or 'Gnarly' refers to the production/selling name assigned to the thickness of the material used to build the K30 designed pipe. Clear as mud right?Jeb wrote:You could always contact FMF to be sure . . . 2001kdx is probably right, though
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
FmF has incorrectly stamped pipes in the past. The numbers (-30 and -35) do not always apply, either.
This is true: The rev profile pipe has a larger cone circumference than does the torque profile. At their largest point:
The rev is 14+"......around.
The torque is 13+".
Judging from the proximity of your pipe to the shroud, you have a rev profile pipe. Call it burly, gnarly, gold series or whatever you wanna call it.
Most 220 riders choose the rev profile.
The torque is 13+".
