Damn, rotor blues.
MXOldtimer
Damn, rotor blues.
Post by MXOldtimer »
Thought I had everything covered to do the fork swap.
Was finishing things up today went to put the KDX rotor on the KX hub and screeeeeeeeeeeeeeeeeeched to a dead stop.
My 06 KDX uses 8mm bolts w/ large head, KX uses a small 6mm. Now I have to come up with a front rotor, DAMN!
No riding this weekend. :mad:
kawagumby
Been thanked: 3 times
Post by kawagumby »
Just drill out and tap the KX hub to accept the KDX rotor and bolts. That's what I did and it worked great.
Colorado Mike
Post by Colorado Mike »
I would just use a KX rotor, bound to be cheaper in the long run. The MX parts are usually more available.
Mike
'04 KDX220
MXOldtimer
kawagumby wrote:Just drill out and tap the KX hub to accept the KDX rotor and bolts. That's what I did and it worked great.
I thought about that but there isn't much meat left on that KX hub around the bolts.
I also thought about redrill'n some holes in the rotor but once again there wouldn't be much meat left on the rotor itself.
MXOldtimer
Colorado Mike wrote:I would just use a KX rotor, bound to be cheaper in the long run. The MX parts are usually more available.
Yeah I've found a used rotor already now if I can get it for a decent price otherwise I'll just buy a new Tusk rotor, around 59 bux.
strider80
Post by strider80 »
KX rotor/hub and KDX caliper works fine for me.
2005 KTM 250EXC
2000 KDX200 (gone)
kawagumby
Post by kawagumby »
MXOldtimer wrote:>|<>QBB<
I worried about that too, but there is enough meat left to do the job. Notice that the mounting tabs are tapered, if you look at the narrowest section they seem too small, but the balance of the tab is more than adequate IMO. The slight difference in bolt diameter just isn't enough to make or break the design strength IMO. I use a tusk non-floating rotor on another bike (a kx), and I have had trouble with it developing too much axial runout...squeak, squeak, squeak. I keep having to tap it back all the time - to keep the noise down at low speeds.
Thats why I think the "floating" rotors (kx or kdx) are superior (at least with a four bolt KX hub design).
I have already put about 25 hours on the drilled and tapped KX hub, mostly hard riding (and braking) on really rough single track with tons of chop and have had no issues at all. I've also used that wheel on my KX for more aerial work.
Just my experience, FWIW...
MXOldtimer
kawagumby wrote:>|<>QBB<
I worried about that too, but there is enough meat left to do the job. Notice that the mounting tabs are tapered, if you look at the narrowest section they seem too small, but the balance of the tab is more than adequate IMO. The slight difference in bolt diameter just isn't enough to make or break the design strength IMO. I use a tusk non-floating rotor on another bike (a kx), and I have had trouble with it developing too much axial runout...squeak, squeak, squeak. I keep having to tap it back all the time.
The "floating" design is superior (at least with a four bolt design)...and I have already put about 25 hours on the drilled-out KX hub, mostly hard riding in really rough single track and have had no issues at all.
Thanks, if I don't come up with a decent priced floater than I'll get out the tap and go that route.
Thanks again
MXOldtimer
Today's brainstorm
Deleted Pic's
kawagumby
Post by kawagumby »
Yet another innovative approach! :supz:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That's using your nogin! :supz:
Green Hornet
Post by Green Hornet »
Another NOBEL PEACE PRIZE Nomine :supz:
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
MXOldtimer
I forgot to follow up on this.
I had the right rotor bolts on order. When they showed up they had the over sized heads w/ correct length threads. My method worked but it was a hell of a lot of work compared to getting the correct rotor bolts and screw'n them in.
Ohhhhh well, I had fun for a few hours making those spacers. :grin:
04 KX-250 Hey.....at least it's green and smokes.
06 KDX-200 for off road play. Gone but not forgotten
07 KX-250F SOLD! I thump no more.
