"so I are want to get rid of it," wow i cant even figure out what that means.GhostRider wrote:I dont always ride sand though, so I are want to get rid of it, would a bigger pilot do the job, strange thing is im runnin a 42 pilot which Is I think, the biggest pilot people with cgk needles use. Some people say that if the jetting is too rich off idle you can get 4 stroking, which im assuming is a bad thing, what is 4 stroking?
Need advice on gearing
- Ryan
2001 kdx220
1987 honda xl250
1987 honda xl250
- GhostRider
the slight bog. Also m0rie how does the DGK change things as even with the CGK needle it still feels smooth does DGK make it feel really smooth?
http://kdxrider.net/forums/viewtopic.php?t=4320
What is 4-stroking?
Re: '..straight off idle..'
Your idle speed may be too low considering, '..response well h0ly sh*t just snap the throttle a bit and the wheel pops right up and you have to yell at it to get it down again. '
A quick snap from idle to full throttle is unlikely to result in immediate response.
Consider the carb has no accelerator pump, power jet, etc. Carbs will generally not be perfect everywhere. That's just the nature of the beast. If they WERE perfect, there wouldn't be fuel injection.
No one need to nit-pik that statement, btw. It is correct.
What is 4-stroking?
It's not always a bad thing. Shouldn't happen when you're asking for power.Somebody wrote:It's a 2-smoke firing every 720º (like a 4-stroke) as opposed to every 360º as a 2-smoke generally should.
...º as in cranky rotation.
- m0rie
Give a 40 pilot a try and see if it cleans up the low end. If your running the CGK in the #2 clip position, try it in #1 with the 42 pilot and see how that works.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- GhostRider
im running a cgk #1 clip with 42 pilot wont a 40 pilot make things worse ( i.e leaning the mixture I thought richening would work, I only get the h0ly sh*t response if I get the revs just slightly past idle.
I might try the #2 clip with 42 pilot would that help or am I going completely the wrong way. I dont expect it not to bog if I snap it straight open but it is actually worse than it was before untill you get the revs just past idle.
The bike pulls strongly across the whole throttle range other than that and going at half throttle in 3rd gear I can snap the throttle and I get wheelspin, Im happy with the results can you also confirm whether I can get morepower
or does my explanation of power seem about right, just asking cause I havent fiddled with the needle clip much, I put it in the #1 clip it worked great so I left it there.
My throttle response was much better after lowering the clip by one position. Mine used to have a hesitation right off idle too. Downside was more spoo.... But the main thing is that the bike performs.
- GhostRider
I have no spooge although it does smoke, but the needle cant be lowered anymore its in top clip, may be switching to a leaner pilot would work but I thought the slight bog was cause it is running to lean on the pilot? my fastest idle on the aircrew is around 1 turn out and I thought that would be about right and not in need of going leaner.
Not lower the needle... lower the clip... i.e raise the needle. Check it out and see if that solves the issue. It usually is the pilot for this issue but it made no difference in my situation... raised the needle.... and suddenly it didn't have that hesitation anymore....
- GhostRider
Will try raising the needle (I should read post properly next time
The only thing which put me off that was because jd jetting said that the fuel just off idle was not changed by raising the needle.
And also because the needle clip affects mid range so didn't want to ruin whats already working really well there.
Also because m0rie says I would probably end up with it in the #1 position, so whats the chance of the #2 working well.
- m0rie
You'll never know what clip position or needle works best until you try them. I suggested the #1 and #2 clip position with the CGK because i've personally ran them and they worked well. Others have also ran them in the same positions and had similar results. Your bike/conditions might be different enough to warrant and different clip, needle or jet choice.GhostRider wrote:Will try raising the needle (I should read post properly next time)
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- GhostRider
I tryed my bike in the #2 clip Seems to work quite well, I just dont know which clip I like best. Plus I figure its safer being rich in the #2 clip than #1IMO and all..strictly related to anecdotal personal experience, but do NOT run an older fine-wire plug in the sand!! Use a new plug, no smaller than an -EG, and preferably an -ES.
But is it safe to run an EG plug in the sand Ive heard it gives you a good boost in bottom end. Im running a B8ES at the moment.
Told ya!
- GhostRider
