What kind of improvment with a 200 carb?
- Ryan
What is a 200 carb going to give me and what will it take away? Also does anyone know if it will fit the stock air cleaner and reed cage of my 220? Or is it the same size.
2001 kdx220
1987 honda xl250
1987 honda xl250
- m0rie
You'll gain top end and loose little if any low end. Send out your stocker to RB and you'll gain all over.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- krazyinski
I have a 36mm carb on my 220 but the cylinder was ported and the head milled. for what I dont , but fredette did it. compared to the stock 200 its like a 250, enough power to hang with and out excelerate a 06 300xc out of the corners but the KTM had a 220lb rider and the KDX had a 165lb rider. that tid bit is for the KTM guys I dont want ya to spaz !
Green Hornet
You will not loose much low end. You will gain more mid & upper though. The RB Carb/Head Mod will give you the BIGGEST Power Spread.....
And YES it will fit the stock boot
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
OOPPSSSS
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Then WHY change it?Ryan wrote:i was thinking about sending out my carb but i would like to keep it stock if i can.
Green Hornet
Nothing.........My Dementia acting up
Dry up!!!!!Why don't ya like the mud......The leaves are the worst
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
Don't the Hypos & Crack Viles in Newburgh flatten the tires
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
