Pushrod Nut size
radonc73
Pushrod Nut size
Post by radonc73 »
I will be replacing my springs in the next week or 2 and was wondering what size wrench I need to grind down to remove the pushrod nut. I will probably just buy a cheap one and keep it for future uses.
Thanks for any help
Riding is living everything else, is just waiting.
Master of the casual pace
83 KDX 200
93 KDX 250
84 YTM 225 DX 3-WHEELER
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
OK... huh? :blink:
scheckaet
Post by scheckaet »
heeu... what??? No need to grind anything :wink:
radonc73
Post by radonc73 »
In the fork service thread it says I need a special Kawi tool or a ground down wrench to remove the pushrod nut to get the springs off.
2. Push down the fork spring and insert a wrench on the push rod nut, fig
Note: Kawasaki sells a special wrench for removing the pushrod nut (part number 57001-1286). A normal open end wrench can be ground thinner if needed.
I was just wondering what size wrench was needed but if I don't have to grind all the better.
83 KDX 200
93 KDX 250
scheckaet
Post by scheckaet »
You can do it without it. It's tricky but you don't have to ruin a wrench just for that. If I remember correctly, I jammed a screwdriver or something to keep the spring down and get access to the nut.
radonc73
Post by radonc73 »
OK, thanks. I wasn't going to buy a special tool for it if I didin't have to. I just wanted to have all my ducks in a row before diving into it.
83 KDX 200
93 KDX 250
canyncarvr
Post by canyncarvr »
Here's MY speshul tool. Yep!! Designed, engineered and fabricated all by me!! :shock:
Uh...it's a piece of sheetmetal, btw.
scheckaet
Post by scheckaet »
Do you have a patent on it :mrgreen:
radonc73
Post by radonc73 »
Of course don't you see the circled TM?
83 KDX 200
93 KDX 250
scheckaet
Post by scheckaet »
ma bad :lol:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Man! No one uses vise-grips for anything anymore...... :?
saddletramp
Post by saddletramp »
Just jam your finger in there to hold the rod up, then after your hands are good and oily just reach for anything in the vicininty oh and make sure there are no paper towels anywhere. :grin:
2000 KDX 200 97 KX 125 Front End
1996 CR 250
03 RM 65 2000 YZ 80
KDXer
Post by KDXer »
saddletramp wrote:Just jam your finger in there to hold the rod up, then after your hands are good and oily just reach for anything in the vicininty oh and make sure there are no paper towels anywhere. :grin:
You forgot to knock over the tub of old fork oil while seaching for your paper towels. :lol:
canyncarvr
:hmm: I didn't know so many of you were watching me in my garage..........
A wrench smaller'n the nut can be used (place the open end under the jam nut)..but it gets a bit wonky because it doesn't hold the spring down 'flat'.
With the Speshul Purpose tool, you can hold the spring AND have both hands free...to get all oily and messy and looking for paper towels.
