Compression Test!
- 2001kdx
Compression Test!
I took a compression test today and was SHOCKED at the results. Here I have a 2001 kdx which was bought new in 2003 but the original owner and ridden somewhat lightly. I bought it in May'06 and put about 1,000 miles on it since then. Here's what's strange - I scored 165, and I am on the stock piston&rings! Somehow I expected it to be lower. I also thought 95-145 was within spec. Do I have a bad compression tester or a bike that is FRESH???
GS
You're "clueless"? And I thought you were "2001KDX"??
Kidding!
So the compression is fine!...... as it usually is.....in anything except severely worn cylinders.
There are many variables in compression testing (temp/throttle position/kicking technique/oil in the cylinder/etc/etc)
But, it seems clear that *if* the cylinder does need rebuilding at this time, it certainly isn't due to low compression.
SO? .....worry about something else!!
Kidding!
- skipro3
IdahoCharley
I did not know if your kidding or not Jerry.skipro3 wrote:Probably a large amount of carbon build-up on the piston head. This can result in too much compression and blowing the seals on the crank. Take care of the piston and head soon.
A large amount of carbon on the piston will bump the measured compression in an engine. But no way is it going to blow any seals on the crank. Reason the crank seals are both under negative pressure during the intake cycle of the engine and only see minimal above atmospheric pressure when the engine is on the power stroke.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
GS
- skipro3
You are right. I meant bearings not seals. Excess compression can affect bearing performance. I doubt this would be much of an issue though. However I have seen, personally, an increase in compression due to carbon build-up in the combustion chamber.
If you can find another comp. gauge to compare with, that would at least confirm your findings.
Pull the pipe and look up in there with a flashlight. Pushing on the kickstarter will put the piston in a position to see the head I think. A mirror and flash light might get you a peak from the spark plug hole too. It isn't hard to pull the head though, just a little inconvienant due to the coolant.
and don't worry GS, I'm only mildly annoyed. At myself for mixing up bearings with seals!! Grrr!! (HAW!!)
BTW was that test with throttle wide open or closed? Engine at operating temperature?
Jerry
- bradf
I have always kept a spare top-end gasket set just for times like this. I know in a few years I will need it anyways for the scheduled inspection and/or re-ring. It is so easy to tear apart, check, fix, and rebuild. Having the set on hand makes it an easier decision.
crf_kdx
For the sake of comparison . . . I've performed three compression tests on my 2005 model. The same drill each time . . . warm the bike by driving it around the block (1.4 miles), use the same off-the-shelf Autozone compression tester, full-open throttle, 10 kicks, repeat once and average results. The results follow:
10-29-2005 with 330 miles -> 162 psi
3-25-2006 with 830 miles -> 165 psi
3-17-2007 with 2400 miles -> 165 psi
My manual indicates a usuable range of 95 to 151 psi. I've simply assumed my gauge was off by 10% but thought the constant readings over time were a good sign nothing serious was amiss.
"There are two kinds of adventurers: those who go truly hoping to find adventure and those who go secretly hoping they won't."
~ William Trogdon
2002 Honda Shadow ACE 750
2005 KDX 200 (mine)
2006 CRF 250X (son's)
2004 TTR 125LE (for sale)
KORHS Series: Senior C
~ William Trogdon
2005 KDX 200 (mine)
- 2001kdx
IdahoCharley
You better be scared2001kdx wrote:Ski, my throttle was closed and the bike was fairly cold, had been ridden an hour earlier. I probably should have used different variables.
Tommorow I will do as you say and take a look. I'm scared as to what I'm gonna find!
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Re: ' I've simply assumed my gauge was off by 10% but thought the constant readings over time were a good sign nothing serious was amiss.'
Th'ar 'ya go!
Worry about the number less (Be sensible. A reading of zero is never going to be good!), and use it as a tool as described above.
Th'ar 'ya go!
stevemacisaac
Compression Test!
Well, now I'm worried. Bought a KDX 1998 from a buddy who maintained it to the tee, never did a top end. Also bought a KTM 300 EXC from him (he and his wife were getting on in years) and my son and I have been riding them for a year. Change the oil, etc., religiously.
The KTM fouled a plug yesterday, it was the original plug, my son was riding it. New plug, started right up. Local excellent mechanic said "check the compression" before anything else. Checked it, it with a brand new (this morning) Craftsmen gauge. 195psi. Then checked the KDX, it was 172 on the same gauge. Is the compression too high on the KDX? His wife rode it, never had the head off.
Is it possible the gauge is reading too high? Or is there too much carbon on both? They run like tops -- except the surprise with the KTM fouling a plug. We mix the oil like we're arming the fuse for nuclear bombs -- and always err on the "more oil than less" side, and the pipes shoot a lot of sponge.
Any hints or tips? Love the site, and thanks for the accumulated wisdom and kind attention.
- 6 Riders
Re: Compression Test!
Too much is not "Good", mix the KTM at 50:1 and the KDX at 40:1 using quality oil. If your spooging, you are going to build up carbon on the piston.
- Tedh98
