My overall view of my kdx 250 is that it runs strong and does quite well in the power department but the bike itself doesn't seem to handle the power well.
Anyway,
I unintentionally looped it last weekend. It was pretty bad as my feet never had a chance to touch the ground when I went over
My friend has 18 acres that has some trails cut in. Slow and technical.
I had an issue getting through a 8 ft. deep ditch that had no transition at the bottom. It looks like a "V" and once out of the ditch it is a slight but good uphill climb. Been through there many times with no worry's.
This time I remembered blipping the throttle to lighten the front end at the bottom. The bike actually seemed to speed up as the front got past the transition and it caught me off balance. To make a long story a bit shorter I ended up trying to hang on, standing and my weight to far back and at the same time I unintentionally opened up the throttle.
Then before I knew it I was on my back about 20 ft. on the other side of the ditch having put my back into a position it has never been before. I actually felt it stretch before I landed on it. Bikes all good
Could of been bad. First time I ever looped a bike while I was still riding it.
I'm either going to swap suspension, get a different bike all together, or transplant the motor into something lighter and more agile.
I would like to keep the bike but I know a fork swap will not help the bikes geometry. Who knows....I sure like the bike and don't want to give up on her.
