Steering Stem, Pressed Down and Out or Up and Out?
skipro3
Post by skipro3 »
That's what I thought too. He'll read this and reply I'm sure.
Jerry
89kdx200rdr
Post by 89kdx200rdr »
wow you guys are too hi tech
1989 KDX 200
2003 KX 250
2006 KX 250F
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
KAY DEE EXER wrote:
Indawoods wrote:The KX stem has a clip at the bottom to prevent it from being pressed too far in, so this alone gives you an indication of how it is pressed in. :wink:
In my gallery theres a photo off the stock KX bottom clamp, where's the clip you mention? Thanks
On the bottom...The gap between the stem and the clamp... look inbetween... you will see a thick flat C clip in there.
skipro3
Post by skipro3 »
Inda, did you have the roll pin like Trev shows in his gallery on your lower tree?
Jerry
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That is on his KDX tree.... You'd have to ask m0rie....
skipro3
Post by skipro3 »
My mistake. I thought that was the KX clamp. Guess I should learn to read his captions or something. I'm going to use the photo and take my lower KX tree with my KDX stem and have a local shop install a pin for me. Just some insureance to the knurling now used to keep the stem snug.
Jerry
KDXer
Post by KDXer »
On the KX bottom clamp there is not even a 1mm gap between the stem and the hole it lives in. I can't see how a c/clip could fit in that tiny gap. There is no clip visible at all. :cry:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Press it out... then you will see what I'm talking about. On second thought... I still have my KX stem... I will take a pic of it today...
KDXer
Post by KDXer »
No problem. So you can't actually see it until the stem is pressed out?
