In about 2-3 weeks ill be breaking in my new top end
motofox2006
Post by motofox2006 »
Last week I put my bike in the reconditioners for new piston and rings and a sleeve put in due to a big scratch in the bore, Im also getting the head moded at the same time, at the moment my jetting is a 158 main and 45 pilot, I do believe the main is to rich and the pilot is too lean.
Is it bad if I break my top end in with this jetting because I can hardly rejet at the same time as breaking it in.
Has anyone had their head modded just by itself, does it increase power much.
And my power valves are being replaced because they had all snapped and werent working at all will this make me notice much difference. I cant wait to feel the results.
E series 91 KDX
KillDozer
Post by KillDozer »
With just your power valves working you will notice a huge difference.
motofox2006
It felt powerful as it is not as powerful as dads yz400 but it felt powerful.
E series 91 KDX
crazyaboutriding
Post by crazyaboutriding »
it will definately help. once i had gotten mine fixed after not working it felt like a whole different bike. as of now it has almost NO low end.
Kevin
'00 KDX 200
motofox2006
How often do the powervalves need replacing?
Does anyone know about the break in
E series 91 KDX
motofox2006
can someone answer my question please
E series 91 KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I have never replaced my power valves on either my 92 or 95 KDX.
So how often depends on how often you manage to break them.
motofox2006
E series 91 KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
A question is usually followed by a question mark my paisty friend...
You should get it in the ballpark for your elevation and temps... and you haven't given any info on that....
motofox2006
My main is one size rich, I think, my pilot is one size lean I think, is it bad to break in my top end with slightly off jetting? because I cant jet it why breaking it in
E series 91 KDX
hart125
Post by hart125 »
I just caused a bunch of trouble with my new piston and cyl by having it too lean. tolerences are the tightest when new so if there is a little too much heat that will be when its the most dangerous. Just be sure your too rich for the first 5 gallons of gas or so. then lean out. Id consider a 48/160 for breakin unless thats too rich to run.
motofox2006
Thats alright what you said there but ive heard that you shouldnt have to richen the fuel mixture to break it in all i was asking if it is bad to break in the top end with a lean pilot/ rich main
E series 91 KDX
tha_reids
Post by tha_reids »
I would be patient. Make one change at a time. You can end up with a poorly running motor and not have a clue as to why or what upgrade had what effect on how it ran. If you want to be thorough save that for when your checking tolerances.
I don't think you'll have any issues with your jetting. Save that for after you break-in.
motofox2006
Ok thanks mate
E series 91 KDX
hart125
Post by hart125 »
motofox2006 wrote:Thats alright what you said there but ive heard that you shouldnt have to richen the fuel mixture to break it in all i was asking if it is bad to break in the top end with a lean pilot/ rich main
most of my damage in the past wasn't from too lean main,, its been too lean on the pilot.. the damage is less at lower rpm but it still happens and it's a lot harder to tell when its happening, thats why I would at least go to 48 on the pilot
motofox2006
So when you break in an engine do you richen the jetting or not?
E series 91 KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
No... should be exactly how you would ride it.
hart125
Post by hart125 »
yes, exactly as you would ride it if its jetted perfectly as you ride it.(most people dont know) If your not sure,, and it could be lean, error on the rich side! especially if its cold out when your breaking it in
motofox2006
My jetting is a 158 main and a 45 pilot with 1172n needle in second from top clip position. Can someone give me the ballpark for my jetting for my elevation, and temp. my temp is 10 to 25 degrees celsius, my elevation is 0 - 600 feet above sea level, I ride mostly sand.
E series 91 KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
What exactly do you have? a 200, 220, 240? What size carb? I tried looking for what you have without any luck....
