The brackets that mount the uni-trac linkage to the frame and also mounts between the swing arm and engine. Will these interchange with a KX of similer years? What the deal is is that I have one that needs replacing (long story) I have found one that goes on a 94-96 KX125/250 but I can't find the part number to see if its the same. The part I need is 32037. I have looked at a few schematics but I cant find the KX part.
Thanks
Vinny
Shock brackets on a 93 KDX200
vinny
- tim
vinny
That picture doesn't show the brackets I'm talking about. I can't seem to find it in the KX schematics anywhere. Under the KDX schematics its listed under Frame fittings or frame fittments. Something like that. There are 2 of them, left and right. One shaped different than the other. The linkage itself accually bolts to them and that is what holds the linkage to the frame
Vinny
Vinny
- quailchaser
1993 KDX 200
32037-1535 left side
32037-1536 Right side
The reason you can't find this for the 94-96 KX 125/250 is that it is part of the frame for those years.
The KX 125/250 J series has those brackets (1992-1993)
KX125/250
32037-1581 LH
32037-1582 RH
So does the H series (1990-1991)
KX125/250
32037-1522 left
32037-1523 right
So does the G series (1989)
KX125 G 1989
32037-1529 left
32037-1530 right
KX250 1989
32037-1495 LH
32037-1496 RH
F series 1988
32037-1461 LH
32037-1462 RH
E2 KX125 & E1 KX250 (1987)
32037-1420 LH
32037-1421 RH
All the brackets look similiar in the diagram...but, they all have different part numbers.
KX125/250
32037-1581 LH
32037-1582 RH
KX125/250
32037-1522 left
32037-1523 right
KX125 G 1989
32037-1529 left
32037-1530 right
KX250 1989
32037-1495 LH
32037-1496 RH
F series 1988
32037-1461 LH
32037-1462 RH
32037-1420 LH
32037-1421 RH
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- quailchaser
vinny wrote: I wonder what the last four numbers designate?
The first part of the number (the stuff before the -) is how KAW categorizes the part. The second part of the number (the stuff after the - ) designates the specific part in that category for a given application.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
