Hi KDXERS,
I have a question which may be dumb but I'm a new owner of a 06 KDX200. I was out riding in some deep sand and took a spill, no harm done but when I got home I noticed the fuel overflow hose from the gas cap was loose on the other end. One end was still in the gas cap but the other end was hanging loose over the handlebars. I could not tell where it was supposed to go or what it was supposed to attach to (probably another drain hose but I couldn't see it). Could someone take pity on me and tell me where it is supposed to go or what it's supposed to fasten to? Thanks. By the way, the hose is about 8-10 inches long.
Pete
06 KDX200
Gas overflow
Pete Fetz
- scheckaet
the hose from the cap goes in the sterring stem hole underneath your handlbar. it's not plg to anything at all on this end
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- quailchaser
Yep. It's not an overflow hose though. It's a vent hose. It should have a short pcs of hose out of the gas cap, then a small (approx. 1") plastic check valve, and then a longer pcs of hose from the check valve. It's suppose to let air in as fuel is emptied from the tank, but not allow fuel to flow out during an ooops moment.scheckaet wrote:the hose from the cap goes in the sterring stem hole underneath your handlbar. it's not plg to anything at all on this end
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- radonc73
Re: 'It's suppose to let air in as fuel is emptied from the tank, but not allow fuel to flow out during an ooops moment.'
This is obviously overlooking the obvious.
In any decent wreck, the vent tube is going to be ripped completely off the cap..in which case it don't matter whether it's venting or..uh..hosing.
Works for me!!!
Works for me!!!
Pete Fetz
