K & N filter
Re: 'I was never saying the fit of the filter had ANYTHING to do with how much dust it let into the motor.'
Neither did I.
Neither did I.
- KDXer
If CC wants one then they MUST be good.
In all seriousness, they possibly have a fit issue, they DO have a filtering issue and the price is, well, bend over...
My advice is don't waste your time, money and possibly your engine. Get a tried and tested Uni or TwinAir filter and have some peace pf mind.
Or buy the K&N and let us know how you like it...
- Mr. Wibbens
>|QBB<[/url]
Least til it falls apartKDXer wrote: Uni or TwinAir filter and have some peace pf mind.![]()
- KDXer
>|QBB|QBB<[/url]
[/quote]
Never seen a TwinAir do that. If you don't use the proper cleaning procedure you will eat the glue away like pictured above.
What is that ?? A Uni ?? They are known for having crap glue that gets eaten away if you use harsh chemicals.
[/quote]Never seen a TwinAir do that. If you don't use the proper cleaning procedure you will eat the glue away like pictured above.
- Mr. Wibbens
Used just good ol' gasoline
jowens66
Take a look at the material the K&N uses, you can nearly see through it. It doesn't filter as good as a foam filter, but it does let alot more air get through, which in turn, up's your motor's performance. Its a risk, more horse power, with a bigger chance of something getting to your motor, or less air with a foam filter, and little to no risk for your motor.Indawoods wrote:Makes no sense to me.... if you can see through it... dirt can get through it.
If you do decide to run the K&N, i would suggest their little filter covers (not sure of the name).
But if i can buy a K&N filter and the little covers for it, and it fit good, and get more power, and be safe for the motor (with the covers), i will shell out the fifty bucks for it.
jowens66
You said above, the fit of the filter that lets the most dust in an engine is beside the point.canyncarvr wrote:??
The fit of a filter that lets 'the most' dust in an engine is rather beside the point, is it not?
Who cares how something that doesn't work fits?
And then say you want one?
Bofus wrote: This piston fits perfectly!!!Refus wrote:But it's gotta HOLE in the top of it!!Bofus wrote:But it FITS perfectly!!Goober wrote:I WANT ONE I WANT ONE I WANT ONE!
We are talking about a K&N filter. You were talking earlier of how the K&N would fit on a KDX. I haven't seen one a KDX and was wondering about the fit of it. We were also discussing that the K&N may let more dust, dirt, sand, ect, into the motor. So no, it is not beside the point to talk about the K&N because i am wondering about the fit of it, and i'm wondering about the filtering capabilties.
I never stated that the filter didn't work. I stated that if it fit correctly, i would like to have one. The filter does work, maybe not as well as a foam filter because the foam is much more dense and the air has more to go through, therefore it gets filtered better, but the flow is hindered compared to the K&N. So again, the K&N works, but probably not as good as a foam filter.
Has there ever been an issue with the air flow of a foam filter?
Not that I can recall.... so... why a K&N?
- quailchaser
CC your post are typically quite amusing as well as informative...if not a tad confusing at times? But, this is the funniest post I've read in a long time. Then again, it's pretty late and I only had 4 hours sleep last night.canyncarvr wrote:??
KN filter without a filter skin (or thier expensive "pre charger" aka filter skin) here in the desert will let most of the desert into your engine. Also, a high flow filter is more effective on a 4T as they are just Air pumps anyway. More flow in and out = more power. A 2T works with a supercharger type effect and the benefits are not the same. I would venture a guess that you would not feel (seat of the pants) the differnce between a well jetted KDX with a foam filter, and that same bike well jetted with a KN.
Except your wallet would be thinner and your risk of particles passing into your engine will increase. There are many mods that have benefits that are worth the added cost. I don't believe the KN is one of those. But, you should judge things on your own. Let us know how it works out.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
jowens66
No not that i can recall, and i never said there was an issue with the air flow of a foam filter. BUT, a K&N does provide better airflow. Why a K&N you as? The power increase may be too small to notice, but then again it may not be. We won't know until we test one. Thats why.Indawoods wrote:Has there ever been an issue with the air flow of a foam filter?
It's your motor.....
it175
So... now that we slammed K&N real good.... and you guys slammed my Ready filters... which is worse?
KarlP
- quailchaser
Flip a quarter 50 times and record the results.Indawoods wrote:So... now that we slammed K&N real good.... and you guys slammed my Ready filters... which is worse?
Tails=K&N, Heads=Ready Filter
At the end of your scientific quarter testing, let us know th results.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- Mr. Wibbens
I'm not planning on running one on the KDX
Out of the two I do have, neither one can you even come close to seeing through,
And cost? well the price of a Vstrom factory replacement throwawy filter is about $40, K&N was only $8 more
