Fork guards
wylde3
Fork guards
I was thinking about getting a set of neoprene seal savers and was wondering what I would do for fork guards? Any ideas, thanks.
2006 KDX 200
2006 KDX 200
RSU forks?
You want to protect the uppers (inners)?
You don't like the OEM bellows protectors?
I'm not knowing what you're after.......
RSU=Right Side Up (OEM)...as opposed to...
USD= Up Side Down (KX, YZ, CR..whatever)
I don't know what you read, but if you have SealSavers or a like product on the upper tube of the OEM forks, I don't know why you would need to worry about any further protection. I wouldn't use short ones. Personal preference I'm sure.
Using SealSavers on USD forks works well..and so does using a USD type fork guard to protect the SealSavers...like so:
I wonder if that is what you read about?
Again, for the OEM configuration, SealSavers should work just fine.
wylde3
I read that post from you LOL.
http://www.kdxrider.net/forums/viewtopi ... t=neoprene
quote: "Yup. Gotta have fork guards...in my never asked for opinion.
If I get smacked by a branch hard enough to just about knock me off the bike...I don't suppose a neoprene bootie would help much. That does happen to me regularly..I'm sure it happens to the front wheel assembly all the time!''
I appreciate your help
That review is for KX USD's.
What Inda said...I had a hunch that what you read indeed referred to USD forks. Never heard of such a thing on the OEM forks.
I have never seen a fork guard setup for RSU forks. Not in the USD 'style' anyway (stiff plastic/carbon fiber bolt/clamp ons). The idea doesn't make any sense to me.
Sooo....no. I have no ideas.
- m0rie
>|QBB<[/url]
Ask and ye shall receive:canyncarvr wrote: I have never seen a fork guard setup for RSU forks. Not in the USD 'style' anyway (stiff plastic/carbon fiber bolt/clamp ons). The idea doesn't make any sense to me.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
- scheckaet
Do you REALLY need fork guard on the oem if you have seal saver?
Since it's on the top, it should be far less prone to rocks, bangs, roots...unless you fall a LOT. IMHO the accordian guards should be enough (but don't look as kool
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
wylde3
Those are 43mm forks....
I'm serious! They are 43's....
wylde3
Ok panic attack over
I just got off the phone with Seal Savers and they said I orderd the right ones if I was wanting to replace the stock accordian covers. They said zip tie both ends and they would be just right to allow for suspension travel. They also said if I don't like them they will gladly replace them with another size
luke347
Yea Im pretty sure that drz 475 has a front wheel drive kit on it from the dirtrider internet bike contest, so no thats not a guard if im correct, but there are rsd guards for the top my cousin has em on his 95 ktm 300 ill try and get a picture if you want.
ps there from acerbis and they are after market so im sure you can find the
- motorider200
- KDXer
