2003 KX 125, kx 250 forks?
KDXer
Post by KDXer »
FTR I'm running 02 KX250 forks with bladder removed, midvalve replacement kit, gold valves, Racetech .38s and I weigh in at 180lb fully kitted. PLUSH CITY and can still handle 70' tabletops no probs.
bradf
Post by bradf »
>|<>QBB<[quote="I could allways make adjustments with the oil weight/level and shims. [/quote]
This is not a sound suspension tuning practice in compensating for incorrect rate springs
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I agree... I tried some of that and was never happy with the results. Get the proper rate springs to start with... you will be glad you did.
krazyinski
Post by krazyinski »
I was running .43 on the KX forks at 175lbs and they were indeed making me want to scrap the KDX for parts and go a another color but after .40 springs and a little valving BAM!!!! magic bike appeared.
TopperHarley
Post by TopperHarley »
well, with everything said, think I will try the 2000 kx500 w/.40 springs as they are on the 03. Maybe just do an oil and seal change. On the 2003 KX 250 forks w/.44 springs for my 02, I will get some lighter springs. And for my 2005 I will keep the KDX forks for now and put 2004 Xr400 .40 springs in. what is the best way to compensate for the longer xr spring? should I cut the spacer or is there an aftermarket I should get??
If you run into Heidi, have her look me up in her little black book and give me a call.
Im feelin a little wild today.
http://stores.shop.ebay.com/GATEWAY2-STROKE
2005 KDX220 mine
2003 KDX220 mine(under construction)
1998 KDX220 1/2 Brother-in-laws, soon his own
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
You can cut the metal one down but most go out and buy some Schedule 40 PVC pipe...1 1/2" and cut new ones.
TopperHarley
how big should they be? just enough to get 3-10mm preload?
2005 KDX220 mine
KDXer
Post by KDXer »
TopperHarley wrote:how big should they be? just enough to get 3-10mm preload?
Exactly.... :mrgreen: Make sure you cut them square at the ends. It took me a bit to get them perfect.
