OEM brake lines
Sky.A
OEM brake lines
seen oem front brake lines go for about $80 . what about steel braided lines ? are they worth it? some say you can get them for about $50. if so where ? even if they end up being a little more then oem they might be worth it right?
Kauai Boy 04 kdx 200
Green Hornet
I'll post the EBAY Link for the Guy I get them from. He's in the UK, complete set is around $40 & you get them by Airmail, within 5 days.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Sky.A
Green Hornet
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- skipro3
I bought some from him too for my KX250. Good deal!
SS lines make a big difference. It's like power brakes since the lines don't streach. Especially during hard braking like steep and long down hills. Much easier to control the feel too. I could tell preciesly when my brakes were about to lock up.
Jerry
crazybrit
Green Hornet
Ask Nick. He may be able to help you. He responds quickly & seems very nice
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Sky.A
Green Hornet
Thats going to happen. Use the front brake even more than the rear2001kdx wrote:This is what the kx's have correct?
Does anyone know a good fix for the rear wheel lock with the rear brake?
I just installed new pads and it locks whenever i'm on a nasty downhill.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
I bought the 99-01? KX Braided Line. The rear is a little longer than the KDX, BUT all you do is LOOP IT in the area of the Master Cylinder.Sky.A wrote:Green Hornet, what year kx braided lines will fit my 04 kdx 200? BTW my bike dosent have a KX USD conversion as i only see brake lines for the kawi upside down forks .dont see any made for the kdx 200
http://kdxrider.net/forums/modules.php? ... _photo.php
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Sky.A
Hornet ......
so the 99-01 should fit ?front and rear even with my OEM Kawi forks??
Green Hornet
I believe so.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Whoa cowboy!
No way a KX with the long brakeline routing is going to work on a CR or 'high' brakeline bike. Besides that..the banjo fittings are different angles.
Tell the man what you want..and he will likely know..SHOULD know. No reason to worry what kind'a KX year fits the KDX brake routing. Tell him you want SS lines for your KDX!
If THAT won't work, at least choose a KX model that has the front brakeline routed high...like they've been for a few years at least I think.
To put it another way:
GH has the LONG (under the fork) front line. Pics are in his gallery.
**edit**
I just asked him about KDX stuff..hi-routed lines and such. I'll let you know what he says.
Nope. Nyet. Nadir nanoo nono.so the 99-01 should fit ?front and rear even with my OEM Kawi forks??
**edit**
Green Hornet
I routed mine above- KDX Style to the KDX Caliber. It does fit. I did not like the under the leg fitment. I do not know what is longer the KX or KDX Line. For fact the rear KX line is longer, but it does work
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Please correct my errors:
Does your gallery not show the under the fork routing?
You took an under the fork line, ran it OVER the fork (hi style)? Where did all the extra length go?
There are two lines on your fork. I took the hi one to be an odo pickup. That is not correct? What's the low line?
I'm cornfused.
I'm cornfused.
Green Hornet
Brad-You're right in this photo. That is what it is. The new kit I bought I routed the line like the KDX or where the OD line goes. I just don't have picks yet
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
OK..so where did all the extra length go to on the front brake line? Going down, under, around and back is a lot further than going AROUND the fork leg.
Green Hornet
It went UP
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
