KX Fork Conversion / Required Knurling?
KX Years on required knurling (Only vote if "YES")
90-91
4
11%
92
0
No votes
93
0
No votes
94
1
3%
95
2
5%
96
5
14%
97
5
14%
98
2
5%
99
6
16%
00
1
3%
01
2
5%
02
0
No votes
03
4
11%
04
1
3%
05
4
11%
Total votes: 37
Ryan
Post by Ryan »
01 kdx stem into a 97 kx lower was not needed to be knurkled.
2001 kdx220
1987 honda xl250
Green Hornet
Post by Green Hornet »
My 05 KDX Stem, pressed in to the 99-01 KX125/250 Lower TT w/o Knurling.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
Colorado Mike
Post by Colorado Mike »
'03 KX125 lower with an '04 KDX stem . Fit without knurling.
Mike
'04 KDX220
motorider200
Post by motorider200 »
99 KX125 clamp to 97 KDX stem needed knurling, the machinist also used locktite. He said you could put the stem in the clamp and spin it around :shock:
97 KDX200(225)- mine
01 KDX220- brothers
97 XR400- dads
strider80
Post by strider80 »
2000 KDX stem into 2001 KX125 triple, no knurling.
Both stems measured 30.15mm DIA
Both triples measured 30.13mm DIA
So it is about a .02mm press fit. It took 10 tons to press out the KDX stem and 1 or 2 tons to press the KDX stem into the KX lower triple.
2005 KTM 250EXC
2000 KDX200 (gone)
canyncarvr
Post by canyncarvr »
OK...so I don't live in Florida and I STILL don't know how to vote. This poll don't look like the others, don't say 'closed' but don't work, neither.
'99 KX250 forks/clamps
KDX stem from FRP (don't know what year)
DID knurl..the clamp not the stem (I think). The machinist didn't have the OD knurlmaker.
Didn't HAVE to do it. The Loctite used (609) was well up to the task had it NOT been knurled. 609 is good for something like .003" difference in mated parts. Mine wasn't that much.
There is another product good for up to .007" I recall. Check the Loctite specs before you jump off a bridge believing those figures.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It won't let you vote ifn you already did.
BlackStormy
Post by BlackStormy »
Bringing this back from the dead, and also my first post here. '01 KX250 did not require knurling. I don't know what year the stem is out of though, as I bought it off of this site.
scheckaet
Post by scheckaet »
01 kx 125 into 05 KDX 200: no knurling
berto2us
Post by berto2us »
2002 kdx200 stem into aftermarket Universal TT 2003-2005? KX125/250.
Had to knurl....
KDX stem didnt want to come out, 20 ton press and copius amount of heat, had the shop guy nervous.
All good in the end.....
Rob
DFW, Texas
2002 KDX 200
TopperHarley
Post by TopperHarley »
2002 KDX stem pressed into 2003 KX250 clamp. No knurling required. 2000KX 500 forks on 2002 KDX frame. Drop in fit. bearings and races are the same. :supz:
If you run into Heidi, have her look me up in her little black book and give me a call.
Im feelin a little wild today.
http://stores.shop.ebay.com/GATEWAY2-STROKE
2005 KDX220 mine
2003 KDX220 mine(under construction)
1998 KDX220 1/2 Brother-in-laws, soon his own
saddletramp
Post by saddletramp »
2000 KDX 200 Stem pressed right into 97 KX 125 clamps. I was going to use my 87 200 stem, it was a little shorter than the 2000 and avoid using the spacer but it would of had to be knurled.
2000 KDX 200 97 KX 125 Front End
1996 CR 250
03 RM 65 2000 YZ 80
it175
Post by it175 »
01 KDX stem into 04 kx 250 clamp. NO knurling. :grin:
If you ride OVER your head. You WILL land on IT!!!
Jeb
Post by Jeb »
I didn't vote because I've got YZ forks in . . . but a '98 YZ125 USD stem required knurling for my '03 220.
"No farmer ever plowed a field by turning it over in his mind" -George E. Woodbury
CLICK FOR PICS!
MXOldtimer
Post by MXOldtimer »
06 KDX stem to 02 KX-125 TC no Knurling.
kawagumby
Been thanked: 3 times
Post by kawagumby »
1999 YZ250 triples to 2001 kdx stem required knurling.
jc7622
Post by jc7622 »
I have a 2005 KDX and bout 2003 Kx forks. I tokk the bottom triple to my buddy's machine shop to press out the stems. The KX stem came out easily. The KDX stem didn't want to come out. We decided to sacrafice the lower clamp on the KDX by cutting a slit in the back side of it. This allowed the stem to come out with less pressure applied.
The KDX stem was not a loose fit. He decided that it neither required knurling nor any kind of Loctite. We pressed it in and then pressed on the bearings using the inner part of an old one to press against.
TopperHarley
a little heat on the KDX lower may have saved it from the scrap bin.
2005 KDX220 mine
plb
Post by plb »
Me:
2005KX fork on 2001KDX need knurling.
My friend:
2001KX fork on 2004KDX need knurling.
Pictures of me:
http://www.kdxrider.net/forums/viewtopic.php?t=5356
Pictures of my friend:
http://www.kdxrider.net/forums/viewtopic.php?t=6360
:supz: :lol: :supz:
riggy
Post by riggy »
I used a 01 kx250 forks for my 97 kdx and It needed knurling .
