swing arm dust covers
- layoutd
is there a secret to getting these out?
can i spray a little "Deep Creep" penetrant along the sides to help them slip off? They seem like they want to tear, if i have not already torn one.
Eatin' ain't Cheatin'
- Jeb
That just means you have never ... or anybody for that matter.... greased your swingarm bearings!
- strider80
From past experience I know my swingarm bearings are good for 3-4 suspension bearing maintains...and the latter is about every six months.
..with the caged lower shock bearing. With the OEM lower shock it was more like every two months.
I do re-place mine using RTV. To remove, I use an orange-stick kind'a thing (actually a nylon fret replacement tool used on Printronix line printers) to lever the cover away from the frame. Once that part of the 'glue' is 'unglued' it comes off pretty well.
Seek and ye shall find.
From the 'Engine Mount' diagram at BuyKawi:
It's callout 'E', 11012.
That translates to:
11012 11012-1591 CAP,AXLE NUT
Yeah...it's NOT a cap for the axle nut, but if you look where 'E' goes, it's the swingarm pivot cap.
There 'ya go!!
That translates to:
There 'ya go!!
- layoutd
So, let's just say that hypothetically one of the covers was dry rotted and had to be dug out in 20 pieces, hypothetically speaking of course. How bad is it to not replace these? just have an extra hole to clean out? Any suggestions for replacement? i imagine that kawasaki is proud of this little piece, i have not looked them up yet.
- m0rie
Mine have been hypothetically missing since I got the bike. I keep meaning to buy a pair of them but haven't bothered yet. So far its just prompted me to tear everything apart on a more regular basis.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
Start with the name of the things...'Axle caps'...and the consider they in fact are NOT on the AXLE. The (rear) axle survives without caps, so I suppose the swingarm pivot could, too. There is more likely crud going to get in between the swingarm and frame than from that outside hole. THAT is pretty well closed off with the pin shoulder and nut/washer.
Now is when m0rie says, 'Washer?'
I doubt those caps are a big deal. I'd buy replacements if I goobered one, though (not that I ever WOULD do that...but speaking hypothetically of course), because I don't like the looks of the empty hole.
AND...what if having them there does in fact (non-hypothetically speaking) keep the swingarm bearings alive!!??
Yes, I do understand that the pivot pin is as much an axle as the rear wheel axle is.
- m0rie
