I agree completly with Inda. There was a night and day difference in the way my bike handled before and after. My stock suspension had xr springs and two of the valve shims removed. I used forks, wheel, and axel from a 01 kx250 that were in perfect shape that I only paid $150 for. Got a triple clamp from a 99 kx125 for $30, and it cost me $20 to have the stems swaped out. In all it only set me back $200. Just go for the swap and I am sure you wont regret it. Plus in my opinion the kx forks look alot better than the stock forks doIndawoods wrote:That other forum thread is pretty funny... talks about alot of machining, respringing, revalving... Horse hockey!![]()
I really don't think there is an easier mod out there for the results gained. Why someone could not follow through with this mod is beond me, Once the stem is pressed in... it takes a matter of an hour to complete.
Parting out his girlfriend's 2004 KX125, just for me?
- motorider200
97 KDX200(225)- mine
01 KDX220- brothers
97 XR400- dads
01 KDX220- brothers
97 XR400- dads
There will always be folks that don't comprehend what this conversion will do over the stock forks. I say... that's fine but you really don't know what your missing. If you want to work with what the KDX has that's OK... but this conversion makes a good bike great.
I didn't see the nut for that axle.... 'course... I don't have a 98 and it may not take one.
- krazyinski
exactly the main diff from 99 up is the axel and nut I hope the axel has a nut cause it needs one. and at least one spacer cause the 2000 axel has one spacer that will work for the 98.Indawoods wrote:I didn't see the nut for that axle.... 'course... I don't have a 98 and it may not take one.
if your unsure I will post pictures to show the diff.
Where did that come from? Besides it's an impossibility...
