Got rid of it. This past weekend.
Replaced the FRP ported USChrome replated cylinder with an OEM (not ported, electrofused) cylinder last week. Same jetting just to keep that a constant for starters. 40/152/DEK-4/#7TV AS at the SSS..2.5+
After the rings seated there was nothing on the fender but a bit of smoke. That over the course of a 100 mile ride last Saturday.
The key was on the removed piston. Thrust faces (front/back) were perfect carbon-wise. Not a speck of carbon past even the first ring. But, on the pin axis? Pretty bad. Plenty of carbon.
Forensic conclusion (my guess and the opine of a good bike tweaker that looked at it too): The cylinder was out of round when I put it in.
I don't have a bore gauge. I did check piston/cylinder clearances when I put it together, but ON the thrust faces because that's what needs to be known. I don't know that a feeler gauge would tell much in this case anyway had I measured on the pin axis.
The 'new' OEM cylinder? Lots more spunk than the ported/plated setup. That's not an apples/apples comparison though, as the ported cylinder had been on a good while..over two years.
...don't ride as much as I used to....
Still, the current setup seems stronger pretty much across the band over the ported cylinder. Won't know that until I get IT replated (Langcourt) and 'recycled'. Re-motorcycled, that is.
It's a relief getting rid of the goo. Flat embarrassing having the junk all over my helmet, my jersey, and dripping onto the swingarm, wheel and rear brake caliper. I'm sure everyone that sees it thinks, 'Gee. Too bad he can't SPELL r-e-j-e-t!'
It ran good though. Well, as good as it could. Kept up pretty well with 250s.
I wonder if the oem cylinder will run without toluene.... Haven't tried that yet.
Another clue: The crankcase had an unusually large amount of oil in it. There is always enough to coat the crank weights when you take the cylinder off, but this time it was t-h-i-c-k with oil.
Imagine that!
If you send your cylinder to USChrome, here's yur sign!
