Keeping My KDX Cool...
- Wudscrasher
I've been having some issues with my 2000 KDX220 cooling. 1st off, I'm not a newbie. My jetting is/should be spot-on, all fluid mixtures are w/in spec. I've had boiling-over issues for awhile now, mostly on gnarly trails. I almost boiled-out in Idaho last month (2000' less than usual) - mainly due to the 35 miles of road to get back to camp. My question is, do KDX's have a thermostat? My water pump works fine, coolant flow is fine...I do have Devol Rad Guards, but I was at a track last weekend, in cool (<80°F) temps, not much dust, and my bike died several times throughout the day and was puking coolant. WTF? Also, does jumping and hammering the bike cause fuel-flow issues? I'm trying to diagnose 2 problems, here. Only engine mods are Wiseco Piston, FMF pipe/TurbineCoreIIQ silencer, freed-up airbox. Any ideas as to why I'd be boiling-up? Don't say I'm not riding fast enough, ya jerks ;) I've been wanting to get a few of you Colorado jokers out for a ride, anyway. TIA for your advise and wise-a$$ remarks...
-- C.J.
-- C.J.
2000 KDX220R
"Big air? I say keep it in the dirt - that's where the fun is. You want big air, kid? Pull my finger." -- Smooth Johnson, Master of the Berm
Your in luck!
This is a great thread on the subject!!
http://www.kdxrider.net/forums/viewtopic.php?t=1044
Proly a bad cap or air in the system. Get a higher pressure cap.
CM has a 1.6 Radiator cap off a CRF450 on his and solved the issue...
- quailchaser
I'll second that.Indawoods wrote:Your in luck!
Oh, and ride faster!
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- krazyinski
cap is spot on the first to cause a problem. most don't think to check it or replace it. as a Surfer in Hawaii I spent my time out of the water working on cars the most common things were radiator caps and distributer cap and rotor.
- Colorado Mike
Yeah, what they said. I wouldn't bother with the 1.1 cap, go to a 1.6 to avoid problems that could occur if something else goes wrong in the future. Here is a link that has even more info: http://www.kdxrider.net/forums/viewtopic.php?t=1054
Mike
'04 KDX220
'04 KDX220
- Firefightinlv
- Wudscrasher
Darnit, I shoulda mentioned I already got a 1.6 cap, months ago, at the recommedation of an old-school dirtrider. Sorry about that.
Boy, do I have you guys by the short-hairs, now! In the immortal words of Dom DeLouise, "OK, faggot! What's next!"
(No disrespect to y'all gay riders, I just love that line from History of the World, Part I
I'm thinking the bike cutting out at the track had something to do with fuel flow. Also, air bubbles in the system were my second-guess (thanks, Inda). And Quail, I already know I need to ride faster, buddy
It's a quandry, and I'll finger it out. The advise I get from y'all helps in my diagnosis of the problem.
-- C.J.
-- C.J.
2000 KDX220R
Green Hornet
I would bleed the system. The start up, take that cap off, fill and let the bubbles come to the top. Also, squeeze the hoses in and out or tap with a wrench to get the bubbles free. Your cap may be bad also, try a new one
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- m0rie
- Wudscrasher
>>Do you still have your puke tank on?
Yes, I do. However, at the track, I didn't use hardly any from the overflow. I expected much more fluid to be sucked up. When I drained the system the other day, the rads were full as well.
2000 KDX220R
Enduro_Mayhem
I suffered boiling-over last weekend on my '94 220 (Jap import) - UK-based enduro course; ground VERY heavy going; woods work/2nd gear technical low speeds (ambient temp low... it IS the UK!), so will flush/bleed the cooling system and try the 1.6 rad cap before anything else.
One question... what 'type' of cap do I need for the 220 - I can see references above made to a CRF 450 1.6 cap and also a KX 250 cap ... are they a universal fit, or model/year specific?
Flyin' the Flag for Team Vintage
