NO SPARK after rebuild of bike
beeds3000
I just put my kdx all back toghter since the frame got painted, I removed the paint to bare metal where the Ground goes and have all the wires hooked back up color to color how it was but I left the box for the lights and the tail light wires disconnected since I don't have any lights on my bike, but it won't make any spark now when I kick it over ???? don't know what the deal is. I even hooked the bad stator up and light wires still nothing I'm out of Ideas any help ????
Geoff T. Biderman
IdahoCharley
Wondering what the "box" for the lights is. Rectifier maybe? Got to feed the coil some regulated voltage - I think.
Engine stop switch "ungrounded" in the run position?
FWIW - Bike electrics not my strong suit!@!
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- m0rie
The coil doesn't need a regulator to operate. Kill switch could certainly be the culprit. Try disconnecting it and see if you have spark.
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
IdahoCharley
beeds3000
STILL NO SPARK (going to shop I guess)
I have the coil grounded, I tried disconnecting the kill switch still nothing, I have hooked all the wires up just the way the manual states, still no shock, there must be something stupid and little I am missing it started and ran fine right before I stripped it down to paint the frame? any ideas before I spend 88$ and hour on labor
Geoff T. Biderman
Put a new plug in it....
When you kick it with the headlight on...does it light?
- RBD
That's correct!
Motor ground points must be free of paint, not just the electronics mounting and grounding points.
beeds3000
beeds3000
BAD COIL MAYBE ??? (voltmeter checked)
I took a volt meter and the motor and bolts on the coil are reading a ground, but when I stick one of the ends of the volt meter where the spark plug plugs in and then on the engine there is no ground, so that leads me to believe my coil is bad, but how is that so if it worked fine right before I took the bike apart to be painted ??? where can I get a cheap coil from online ebay has nothing. ??? does that sound like the problem ???
Geoff T. Biderman
Did you clean all the frames motor mounting points so that they are free from paint?
It's easy to throw money at it but it doesn't really make sense that it worked and now it doesn't.
Please don't start a new thread on the same subject. I then have to merge them and prefer not to have to do that. It loses flow....
The further the ground is from the components that need grounding the worse your ground is.
So, it may be grounded but not well enough to produce spark.
Aluminum is not the best conductor to begin with.
BRAAAAHP!
FTR..just because the bolt holding the ground on measures good to ground has nothing to do with whether the WIRE that's attached with that bolt 'sees' ground.
re: 'it sure seems easier to build that field with a DC current than an AC current.'
Like this?:
That's what those diodes do.
Oh...I didn't cleanup the kill swich comments from an earlier thread. DO note they are not wired in parallel in either case..but IN PLACE of exisitng wire.
Like this?:
