brake line attachment?
Colorado Mike
Post by Colorado Mike »
I'm putting on '03 forks and have the stock caliper and line. I got some stock fork guards that assume you have the KX brake line routing that goes down the front of the fork. I'd rather stick with the KDX routing, but need a way to attach a clamp to the guard. I've seen Ski's method, but he's got the high dollar Carbon Fiber fork guards, and mine don't seem stiff enough at all to hold the line in position, plus as the fork compresses , it would bind on the fork guard guide on the upper tube.
Anybody that has mounted it KDX style, how'd you do it?
thanks.
<edit> was spelling like a dumbass again.
Mike
'04 KDX220
Ryan
Post by Ryan »
mike if you figure it out let me know as i am doing the same.
2001 kdx220
1987 honda xl250
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
When I was deciding which way to go on mine.... I noticed that the brakeline being in the same position for 10 years kinda formed it that way and it didn't want to do anything but stay in perfect position... even while riding.... Go figure!
m0rie
Post by m0rie »
Mike - Just drill two holes at the edge and use ziptys to secure the brake line or pop rivet the brake line clamp sideways and use that.
1989 KDX 200
2007 TTR-50E
Colorado Mike
Vince, my bike isn't that experienced yet, but I'll experiment.
Morie, If I do that, then I have to take off the guide that the fork protector slides inside, otherwise it'll jam up. Right?
Mike
'04 KDX220
m0rie
Post by m0rie »
Yeah, you'll have to go sans guides. I don't think they are really needed though. My fork guards are plenty strong without them and a lot of bikes don't have the guides anymore.
1989 KDX 200
2007 TTR-50E
skipro3
Post by skipro3 »
Yup, loose the guides. Also, those carbon fiber guards aren't too expensive if you find them on eBay. I got mine for about $20, and I've seen them buy-it-now for about $50. They are hugely stiffer than the stock plastic ones.
If you mount a home-made bracket like mine, it helps the plastic ones become stiffer as well. You might find something like a late model guard would fit with some mods. Like the yamahas. If you could get your hands on a set cheap, it might be worth the try anyway.
Jerry
bradf
Post by bradf »
CM, I did exactly as Ski and I used Acerbis plastic guards. I epoxied the back too, just like Ski.
Colorado Mike
yeah, I'll give making a bracket a try.
Mike
'04 KDX220
canyncarvr
Post by canyncarvr »
What. Two holes and a thai-wrap not good enough for you?
Racist or something? Huh? Well? :shock:
If you're looking for a line holder to bolt to that fancy-schmancy bracket of yours...take a look at the Yamaha clamp (any new blue).
skipro3
Post by skipro3 »
I just re-used my stock KDX "line holder" AKA clamp with the home-made bracket.
Jerry
Colorado Mike
that's what I was gonna do (re-use the stock bracket), but since I'm so lazy, now I'm thinking zip-thai.
Mike
'04 KDX220
skipro3
Post by skipro3 »
you guys are making me hungry.
Take some extra ties with you. You'll need it when one breaks.
Jerry
canyncarvr
The stock clamp is straight.
The Yamaha clamp has a curve to it.
