new 200cc Beta XTrainer offering, & the state of 2-stroke off-road new models
Has thanked: 322 times
Been thanked: 146 times
This is some interesting news, Beta is now launching a new size of the XTrainer, formerly a 300cc-only platform, with a similarly milder tuned 200RR engine in a slight variation of the XTrainer 300 chassis!
https://www.advrider.com/newhttps://www ... -for-2027/
I was already quite pleased to see that they began offering (for 2026+ model years) the X-Pro variants of the full size range of off-road bikes, the 125RR X-Pro, 200RR X-Pro, 250RR X-Pro, and 300RR X-Pro, targeted towards hard enduro with a softer suspension tune, and a re-worked frame that allows a noticeably lower seat height, a formula that can work well for both amateur/novice riders as well as those highly skilled riders seeking out hard enduro terrain obstacles frequently.
https://www.advrider.com/hit-the-trail- ... stateside/
Now, on top of the standard 125/200/250/300 RR versions (with oil injection and Sachs fork/shock), the RR Race Edition versions (KYB suspension vs Sachs suspension, premix, etc), and the RR X-Pro versions (lower seat height, oil injection, softer plush valving on the Sachs suspension), they also offer not only the detuned version of the 300RR engine in the XTrainer 300 chassis (which by the way has very similar geometry to the KDX200/220), but now the XTrainer 200!
This is incredible to have all these options, but wow... it has my head spinning as to the expanded size of their model range vs their overall sales numbers... Beta is definitely my top pick of the new model bikes overall with their 2-stroke ### RR off-road/enduro like and the XTrainer trail bikes, but WOW.... That's a lot of models for Beta to manage!
I'd think they'd be better off to thin things out a bit with maybe only a 125RR X-Pro, 200RR X-Pro and 300RR X-Pro (removing the 250cc version), and/or if the actual main frames are different and not just the seat subframes on the X-Pro vs the standard and RR Race Edition models, I'd hope they'd simplify things so that at the core, so that they are the same parts with just a lower seat subframe mounting and different subframe, seat, and rear plastics etc... It seems like it'd be a management nightmare juggling so many different models. Does anyone else have these same thoughts?
Re: new 200cc Beta XTrainer offering, & the state of 2-stroke off-road new models
It's an interesting read here to learn that the X-Pro versions have adopted something I always thought was great in theory, I believe a Sachs version of the Showa SFF fork! They call it the SHC suspension, separate hydraulic chamber.
I don't know if this means a closed chamber / twin chamber fork with separate damping oil vs lubrication bath oil, or if it's an open chamber design, but I believe I read that it was an open chamber design, unlike the Showa SFF version which is a closed chamber design. One fork leg contains only damping assemblies as well as lubrication oil, the other contains only one thicker fork spring and lubrication open bath oil... Half the seals and bushings for the damping assembly vs a standard fork layout means smoother action, especially of great benefit when compared to a closed chamber / twin chamber damping type fork... Also advertised to lighten up the front end by 250 grams... every bit helps! I guess this technology from Sachs/ZF has been out since 2025, but there was a bit of a delay getting it on the US-imported models as best as I understand currently.
The Showa SFF on the 2011-2018 ('12-'18?) KX250F had another amazing feature, in that this SFF configuration allowed external fork spring preload adjustment! I always thought these 47mm (1st 2 years) and 48mm (all later KX250F years) SFF forks could potentially be the absolute best way to get plush suspension out of a closed chamber fork setup.... not to mention, far less labor and parts involved in a full rebuild or even revalve! I almost wish I'd invested in a set of those for my hybrid build vs the 2019-2026+ KX450F 49mm Showa Twin Chamber dual spring typical configuration forks... I do feel the upgrade to 48mm tubes on the Showa SFF was essential and pointed out the downfalls of the SFF design, the need for stiffer tubes in order to smoothly carry the weight of the bike offset to one side primarily, although the damping assembly does provide significant resistance as does the coil spring, so perhaps it's not as lopsided of load-carrying as one might ponder... although the damping only provides resistance with suspension travel, not steady state load bearing, which is where the upgrade to 48mm Showa tubes comes in...
I really feel that the refinements of the newest Betas in the past 2 years truly put them at the top of the market as far as best buys, and they certainly have the absolute best warranty handling in the industry, they even replaced an entire engine for a guy who bought a used 1.5 year old bike out of warranty, a bike with only a dozen hours on it, when something came loose inside the engine after only a few hours of riding... and he wasn't even the original owner, and the original owner's warranty period was several months expired even! I think they've got the majority of their glitches worked out now, hopefully.
A 2025+ 200RR Race Edition set up with more plush suspension valving would definitely be my top choice of new bikes, second pick would be the YZ125X bored to 134cc or maybe 144cc, DRT cylinder head, SmartCarb or Billetron Pro Series, and a larger tank and lighting system would be my top two choices of all. I bet I'd be quite at home on either size of XTrainer as well due to the familiarity of the chassis geometry as well, but the engine tune is a lot milder, smoother torquey traits.
If they'd revise the YZ250X and put it in the brand new YZ250FX chassis, I'd highly consider one of those, but I'm a sucker for the KDX200-220/'94-'02 KX125 / Beta 200RR 125RR XTrainer / etc chassis geometries and the advantages of the 200cc class engines in handling traits.
Yamaha has always had a soft spot in my heart for carrying on the torch for Japanese full size 2-strokes when the others in the big 4 had all but dropped them, but at least Kawasaki kept the KX100 and now 2022+ KX112, and... now a full 2-stroke lineup in the works over the next few years following the upcoming December 2026 release of the new KX327X and KX327!
I truly feel that Kawasaki absolutely needs to develop an overbuilt new 125 2-stroke bottom end that can handle a base gasket and crankshaft stroke to make a 70mm bore KDX220R type 223cc top end... Release it preferably in a steel frame derived somewhat from the newer KLX300R, put an advanced carburetor on it (probably meaning a Mikuni due to their superior emulsion tube designs, but only if past Mikuni TMR/TMX/etc tuning complaints can be smoothed out), mechanical powervalve, and a more reasonable seat height at no greater than 36", with 13.8" ground clearance, moderate wheelbase like a Beta 200RR, XTrainer, or 2002 KX125 (just a hair longer swingarm by 16mm-20mm vs the KDX200H/220R for better hill climb stability), wide ratio 6 speed with an extra low first gear, kickstart as standard, electric start of course, or the ability to add it on, and premix... Steering geometry akin to the KDX200H/220R, Beta 200RR, YZ125X, and 1994-2002 KX125... 26.5 degrees or so rake angle, 4.3" trail, for quick turning ability, and with a wide lock to lock range for tight turning in precarious tight technical terrain situations... and a proper frame mounted kickstand like the X models have. LED lighting as well, of course. KYB 48mm open chamber forks and shock, similar to the 2003-2008 KX125/250 and 2004-2005 KX250F suspension, valved nice and plush for trail riding, but with good bottoming resistance. 2.5gallon or 2.6 gallon fuel tank standard. This would be an incredible seller as the KDX models always were, and they would sell incredibly well in this modern age, especially if they call it a KDX. Fingers are crossed that Kawasaki is listening to my feedback on this across multiple platforms!
Been thanked: 57 times
Yes, we live in the golden age of dirt biking. So many good brands with lots of options to fit nearly any type of rider and purpose.
I'm really interested in getting to check out one of the KX327X models. My main riding buddy has already decided that is going to be his next bike. Sadly, I don't think we'll ever see another bike as specialized as the KDX from Kawasaki. Of course, I could be wrong as here we are actually getting a new 2T from them.
