new SmartCarb SC3 34mm advanced metering rod carb option
SpruceItUp
Has thanked: 135 times
Been thanked: 61 times
Re: new SmartCarb SC3 34mm advanced metering rod carb option
Post by SpruceItUp »
I got a response:
"Hi Ben,
Fitment was more of a challenge in the H series bikes than it was the E series, but even so our prior closest size, the 36mm, had spigots much larger than those of the stock Keihin PWK35.
In our new 34mm SC3 we have perfect fitment and clearance for both frame styles.
Shall we send over an invoice?
Happy to answer any additional questions you may have."
Looks like I'm buying another carburetor! haha
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Has thanked: 321 times
Been thanked: 144 times
I came here to post the same news! My friend James who is a member here also got this email as well as some others in some other KDX communities.
I believe that's $50 off the regular price, so now is a good time to jump on it.
Although I had read the email from another forum member's (jz05220r?)!screenshot that he sent me, I just now dug through all the spam and promotional emails and read and replied to mine from yesterday.
Of course as you might expect from me, I sent them a long email about tuning parameters and exactly how the bike was spec'd out that they Dyno tested these on, and asking if they dynoed a 220 model specifically, and if it had a modified head, aftermarket reeds, etc....
I advise them that they will see a large amount of 220 customers that probably already have a Ron Black modified rechambered & milled 220R head or a Jeff Fredette milled 220R head, both of which will run a much tighter squish clearance than stock at around 1.0 mm, with the Jeff Fredette heads requiring a bit higher octane, & the RB had running happily on 90 or 91 octane.
I'll see what they have to say. I offered up Port timing specifications as well if they wanted to know much about the 200 versus 220 if they had not dug in that deep, but I think the info with the heads that I gave them and also questioning about aftermarket reed assemblies is probably the extent of what needs to be discussed outside of supporting modifications done to a select few cylinders.
Usually the RAD Valve and the VForce 3 generally require stepping down one size in pilot jet. I failed to mention that detail to them, although I think the effect will be similar to that of the patented CloudForge Venturi design of the smart carb, so maybe it will not change the air velocity any further than the carburetor itself changes it, although it could enhance the air flow velocity even more by going with the aftermarket reed cages.
SpruceItUp
Nice! It'll be really neat to try this out on the KDX. Hopefully I'll have more luck with it than I have had with my Lectron. It seems like it'll be even easier to tune than the Lectron is, anyways.
I chatted on the phone with Kim at SmartCarb yesterday when I bought it, went through modifications to my bike etc. Just the usual suspects on my 92 in terms of modifications.
This has me wanting to finally get off my butt and go tinker with the KDX again. Can't wait.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
After replying to the customer requests list mass emails that SmartCarb sent out as quoted above, as well as SmartCarb staff doing a pretty exhausting amount of research on various KDX175-200-220 iterations and variants and fitment concerns, I had the pleasure of receiving an unexpected phone call from a Mr. Nathan Dyess of SmartCarb as I was putting away dinner leftovers tonight...
We chatted for a good long while about different KDX 200 and associated variations as far back as the KDX175 & KDX200A, and the 220 of course...
Corey, the main engineer and I believe one of the two founders of SmartCarb is going to get back with me tomorrow on the more technical details that Nathan needed to refer to him for, but to say the very least, I'm incredibly excited about this carburetor.
From talking with Nathan, it sounds as if their long-standing development of this internal venting design is much better at reading and delivering what the engine is requesting/requiring in terms of fuel delivery versus externally vented versions of metering rod carburetors, so much so, that aftermarket reed cages, which on a Keihin PWK35 would generally require stepping down to one size smaller pilot jet, as well as pipe swaps to a different tune configuration of expansion chamber, don't necessarily need a metering rod change.
The one thing he did state however was that milling the head for higher compression is definitely more likely to require a metering rod change as that is a pretty massive variable to alter in terms of the internal ventings ability to compensate.
He also mentioned tightening up the squish band could potentially need this as well although I'm pretty certain that just milling the head for tighter squish also resulting in a much higher compression ratio will be much more so inclined to require drastic changes of swapping out a different metering rod, vs the Ron Black / RB Designs 220 head mod which is a completely re-chambered had to return the compression ratio to basically stock or slightly higher so that the bike is quite happy running 90 octane in any weather or trail conditions. Hopefully Corey can shed a little more light on that aspect in particular.
To summarize a long story that is likely on the Smart Carb website, which Nathan and I also discussed as he reminded me of what I had forgotten.... Corey had been going in depth developing this internal vented metering rod carburetor technology since the early 2000s in the two-stroke engine world specifically for a grant-funded project to make cleaner burning two-stroke snowmobiles. They had actually bought up all of the patents from the originator of the Lectron metering rod carburetors, the guy who sold the Lectron company early on because he wanted to pursue this internal venting design (which wasn't what the majority of the decision makers at Lectron wanted at that time), as he knew it was the end goal and the future. Since then, they have been working diligently for the past couple decades now perfecting this technology that you see almost the end result in with the previous generation SC2 36mm. The SC3 utilizes basically the same technology but is a more refined version which also is easier to manufacture while not having any downfalls that would make the more complex production and design of the previous generation more expensive.
I'm pretty psyched to try this out, so I've got to expedite my top end tear down to sometime next week so that I can be ready to try one of these out here within the next 5 weeks... There's a bit of a lead time on these so that buys me a little bit of time while I get hard at work try to finish up this house renovation along with some hired help from two guys from our riding crew who are eager to assist both for some monetary kickbacks as well as finally freeing me up so that I won't decline any further trail ride weekends!
They've been dyno tuning and testing on a 200H, and have been field testing a 220 as well based off of the dyno results of the 200H.
They felt pretty confident about about metering rods specification, and Nathan had told me that the vast majority of all of their applications use basically a small range of metering rod that spans only five different profiles for I'm going to say something like 85% of their applications, maybe even more, that's just me guessing.
This is a pretty great development now and cheaper than the Billetron, although I do really like the Billetron Pro Series with the latest generation metering rods they have developed... I think the Billetron sales will definitely drop off for the KDX with the price point alone of the other high-end metering rod carburetor on the market for our bikes, the SmartCarb SC3 34mm...
When reaching out to both these companies a few years ago inquiring about KDX fitment, Smart Carb were very eager and enthusiastic to talk to me and even sent me a carburetor body to test fit and machine in any way imaginable that would be reasonable modifications to fit our bikes. The end result was that it did not fit without frame modification. Fast forward a few years and here we are, they have developed this new version that does fit!
Lectron we're not so great to work with initially because they were pretty old school. They actually wanted me to buy and run for full price a billetron mini design for the super mini KX100 type bikes. The guy pushing this said that the billetron would absolutely not fit the kdx, but I knew from the spec sheets and measurements that it actually would fit pretty nicely... The only way I got electron to actually work with me on this was reaching out to their former lead fuel systems engineer outside of his workplace, Matt Denecke, currently of his own company Denecke Racing Technologies... He was really stoked to discuss these options with me, and that was really the only way that we were going to get a listed KDX fitment for the Lectron Billetron Pro Series carbs.... Sidestepping the traditional customer service contact routes and taking matters into our own hands!
Long story short, smart carb was incredibly eager to work with the KDX community on making a fitment based on the amount of requests they continually received about KDX fitment, but Lectron was not so easy to deal with until I contacted the right person at Lectron who the general public would not normally be able to reach through any business channels....
I think these are both awesome carburetors, but I really feel that due to the price point and their eagerness (in both customer service as well as research and development breakthroughs and continual refinements), as well as their domination in the enduro market, the SmartCarb is going to really sell well.
A genuine Keihin PWK 35 Air Striker now costs $425-$450!!!
I'd proven years ago riding the old school powerjet Lectron on my then fresh 220 with an RB modified head, that metering rod carbs were the way to go, as I got excellent throttle response out of that 34mm Lectron, real good power, and significantly better fuel economy than anyone else in our riding crew, who basically all ran PWK carbs on KDXs, KTM 200/250 & a 300, Honda CR125R & CR250R, etc... returning back to camp or to the trailhead, there was never a time where I did not have significantly more fuel left in my tank versus anyone& everyone else... And I was generally riding faster than and farther ahead from everyone, which would burn more fuel typically, as well as doubling back when I'd stop for them to catch up and they would never show up, turning around and helping them on the tricky hill climb spots and other bike recoveries from lay downs.... So more trail mileage than anyone else as well as a more heavy throttle hand, yes still significantly less fuel used.
I have really grown to appreciate the fuel efficiency from the metering rod carbs as well as small turbo diesel engines in my 4-wheeled transportation... VW 1.9L & 2.0L turbo diesel swaps into smaller 4WD pickups etc is another passionate niche interest of mine, to say the very least.
Has thanked: 43 times
Been thanked: 110 times
If these Smart "carbs" are $599 and Keihin PWK carbs are $450, and the Smart carb is much easier to set up & maintain, then Smart carbs are fairly priced
Kawibunga
Has thanked: 1 time
Been thanked: 25 times
Post by Kawibunga »
The Canadian exchange rate is a bit of killer for me......... but you only live once! So just put in the order. A big driver for me is that I think it will run quite a bit cleaner if and when I ever dual sport it as planned.
Go Riders!
4 X KDX 220s - 2 KLX 650s
Been thanked: 19 times
Kawibunga wrote: 09:44 am Mar 27 2026 The Canadian exchange rate is a bit of killer for me......... but you only live once! So just put in the order. A big driver for me is that I think it will run quite a bit cleaner if and when I ever dual sport it as planned.
The KDX’s I’ve ridden with the SmartCarb / Lectron are much much more mellow. Almost too mellow. I found it difficult to loft the front wheel to clear obstacles compared to the “snap” of the PWK. Be sure to post an update once you get it installed!
Slick_Nick wrote: 10:49 pm Mar 29 2026
My friends' KDX200H models with PWK carbs I find a lot more difficult to loft the front wheel at reasonable RPM vs my 220's with Lectron Powerjet carb and Lectron Billetron Pro Series carbs. After Gnarly Woods pipe, timing advanced in between the middle and max advance marks, and some jetting trials, we got my neighbor's 200H a bit more satisfactorily torquey, but it significantly compromised the top end - especially the timing advancing and pipe combo.
The 220 with the Pro Circuit or Gnarly Desert both still loft the front readily although the torque noticeably drops off fown low with the Desert pipe.
The explosive hit of the Pro Circuit Platinum 2 pipe can somewhat be smoothed through jetting / tuning, so it's quite possible Nick's experiences are that it delivers more even fueling, but it also could mean that the metering rod height adjustment or taper specs aren't quite exacting as the individual bike was set up.
I'd really like to see a dyno comparison of an ideal SmartCarb setup vs the PWK35 Air Striker and/or Lectron Billetron Pro Series, but at $450, $600/$650, & $800 each carb (PWK35 QV A/S, SC3, Billetron Pro), that's a pricey bunch plus dyno time access $$$
The "self tuning" carbs will never be as crisp or as snappy as a properly jetted PWK. Sorry, you won't change my mind on that.
I think what happens is a lot of people who switch to self tuning carbs were starting off with an old, improperly jetted, worn out carb. Swapping on anything new would be a big improvement. The very thing that makes metering rod based carbs "self jetting" is also what keeps them from being as crisp as a properly jetted carburetor.
Your assumption might be a little more accurate when referencing the older styles, but the self-venting technology is quite advanced in comparison, and has been considerably advancing for years and years now. I believe the inventor of metering rod carbs and founder of Lectron actually sold the company because the majority of those in charge wanted to continue putting out the technology which you ridicule, rightly so, while he himself wanted to dive very deeply into advancing the internal venting technology. The carburetors are not self-tuning, they absolutely require critical attention to the tuning and setup, however, due to their internal venting design, they do compensate for altitude and temperature quite well.
If you're only measuring wide open throttle peak power, the PWK will perform relatively the same on paper/dyno chart. It's the remainder of the throttle range below 80% throttle where the metering rod carbs in general, especially the latest generation of metering rod carbs and internal vented metering rod carbs excel far beyond the PWK technology.
Also, these are not necessarily carburetors for people who "don't want to hassle with jetting."
That is quite the ironic accusation, which absolutely only comes from people who don't understand them. Yet the same people who are saying that these carbs are for people who don't know how to jet, oddly enough, are also the same who suffer from lack of knowledge of modern fuel metering and fuel delivery technology.
They absolutely do require proper tuning and metering setup, the same as swapping jets on a jetted carb and setting float height, slide cutaway, needle height, needle selection, etc. nearly all the same tuning parameters exist, but the parts involved are just slightly different.
The metering rod carbs, however, ESPECIALLY the internal venting variants, don't require re-jetting for altitude changes, however...
Conversely, to Slick Nick's initial comment, it's quite plausible to view a massive power band hit on a PWK-equipped enduro bike as a Keihin user's jetting & tuning deficiency.... Or even a metering rod carb tuning/setup problem...
Chuck wrote, "They absolutely do require precise tuning and metering setup, the same as swapping jets on a jetted carb and setting float height, slide cutaway, needle height, needle selection, etc. nearly all the same tuning parameters exist, but the parts involved are just slightly different."
Not knowing much about these metering rod "carbs," I thought they were easier than carbs to correctly tune. Now, I'm better informed
SpruceItUp
billie_morini wrote: 12:09 pm Mar 31 2026 Chuck wrote, "They absolutely do require precise tuning and metering setup, the same as swapping jets on a jetted carb and setting float height, slide cutaway, needle height, needle selection, etc. nearly all the same tuning parameters exist, but the parts involved are just slightly different."
The only thing easier from my experience from my Lectron is that the controls in which you tune them with are easier to access, which makes me prefer to tune the metering rod carbs over a standard carburetor. Most bikes I've owned required me to remove the carburetor entirely to change jetting. My KDX (If I'm remembering correctly) you can get away with turning the carburetor sideways and going in through the drain, but just barely, and it's still a pain if you're constantly making adjustments. With my CR125 I have to remove the entire subframe and fuel tank to access/remove the carburetor.
But chuck is definitely right, I was constantly tuning and making adjustments to my Lectron. More than I would have liked at certain points. Thankfully their support is great and sent out the appropriate metering rod once they realized the one in it was not working correctly for my KDX.
The only thing you have to remove the Lectron for is to adjust the metering rod (leaner or richer) or to change it. They are easier to tune in that regard and the smart carb looks like it has an adjustment for the metering rod built into the top of it, so removal doesn't seem necessary at all for tuning it. Which I'll definitely prefer over the Lectron.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
They are easier to properly tune, absolutely, but...they still need properly tuned... They are not self-tuning, but they are altitude compensating.
SpruceItUp wrote: 12:34 pm Mar 31 2026
I find that adjusting the metering rod height on a Lectron, requiring loosening the spigot and airbox boot clamps, twisting the carb slightly, and removing the carb top cap, is far, far easier than changing jets or changing jet needle clip position height. The two thumb screw adjustable supplementary jets on a Lectron Billetron Pro Series are incredibly simple to tinker with, no tools required.
On a SmartCarb, the metering rod is externally adjustable with a clicker dial on the carb's top cap, so even simpler.
No supplemental adjustable jets like most Lectrons, which is a benefit, but makes custom setup tuning a bit more effort, but ultimately ends up in thebest most efficient fuel metering delivery of any carburetor on the market....
Once you've got it dialed, you're good to go until you may swap to a higher compression head or change your pre-mix ratio or drastically change your pre-mix oil type, or perhaps if you go from dry air desert riding to extreme humidity jungle riding. Very few variables will cause a metering rod carb to be adjusted for the current conditions, especially these advanced internal venting versions we now have available to us.
https://smartcarb.com/product/smartcarb ... ki-kdx200/
https://smartcarb.com/product/smartcarb ... i-kdx220r/
This new carburetor model for our bikes is now live on their website!
Just FYI the KDX250D has been on their website for some time because it doesn't have the fitment issues that the newer perimeter frame KDX have.
A KDX guy local to me tipped me off on this debut on their website today.
Nsign
Has thanked: 11 times
Post by Nsign »
Hey guys, after some trouble getting an account set up I'm finally dialed in.
My name is Nathan and I'm a principle at SmartCarb Fuel Systems. My primary role is VP of Production. Our core team has been working with this technology since the mid 2000s, including a few years with its original inventor William "Red Edmonston prior to his passing. It's been a long road with a multitude of challenges but we are now, happily, in a solid place with our core offerings such that we can start having fun expanding into new applications and markets including the KDX200/220.
For many years we've had a gap in our SmartCarb sizing/packaging. 26 and 28mm and then 36, 38, and 40mm with no 30, 32, or 34mm available. Our 36mm was too big to fit without hard frame contact. We've had to say no for years but now we can say yes.
After a 14 month development cycle beginning late 2023 we launched the third generation SmartCarb a little over a year ago with our smaller 26/28mms shifting to an all-new (super trick in my biased opinion) single piece unibody design. Thereafter we began exploring the mid-size range, looking at an upgrade for the Mikuni VM/TM32/34 in two and four stroke applications and of course the Keihin PWK33/35 in that same unibody design framework.
Looking at all of these soon-to-be-outdated carbs one difference is very clear. Unlike the Mikunis, the Keihin PWK33/35 has a full-size carb float system. Big Keihin PWK floats with a full-size carb 3.8mm needle seat. SmartCarb challenges almost everything about conventional carburetion, but old, hard-fought wisdom regarding float bowl capacity and fill rate are respected. No need to reinvent every wheel. So we made a big bowl 34mm SC3 using our 36/38/40mm SC3 float system to replace the 33/35mm Keihins, particularly in thirstier, higher strung 2-stroke applications.
Differing airbox-side spigot ODs for different carb models along with different overall lengths necessitated a common base unit with the option for either ring or extension ring adapters for plug-and-play fit.
Fitment/packaging/throttling having been nailed down the only other thing to do was to dial in the fuel profile (metering rod dimensions and grind angle). Recent improvements in our predictive algorithm and enhanced in-house metering rod rapid prototyping went a long way to speed that process up. We're now design-final and those of you with orders in place should see emails with shipping/tracking in the next week or two. Those interested in our kit can view it here: https://smartcarb.com/product-category/ ... 2-strokes/
Beyond the SmartCarb, our background is in advanced 2T engine development/theory and EPA emissions brokering. That, combined with historical understanding of various 2T modifications, riding styles, and fuel selections, sets us up well to serve KDX owners with all manner of different setups from high comp heads to street riding to ethanol and/or race fuel selection. Notably the SmartCarb doesn't much care about reed, pipe, or silencer changes. One of the nice things about integrated, at-manifold float bowl venting. The float bowl sees the same density/velocity that the venturi does unlike any other carb with external, dangly vent hoses.
I hope you'll receive us well and we are certainly happy to answer any questions any of you may have as we step into this space at long last.
P.S. We've had a blast testing this bike out. It's a sweetheart and its cult following makes total sense. Happy riding!
Been thanked: 57 times
Nsign wrote: 10:09 pm Apr 09 2026 Hey guys, after some trouble getting an account set up I'm finally dialed in.
Welcome! Glad we got it sorted out.
Kelly
I'm eager to get one of these on my bike this season and try it out! With 3 KDX220R-based machines (1 hybrid project, 2 220 bikes), I'll be running an SC3 34, Billetron Pro, and RB'd 36mm/divider-plate-modded/etc PWK35 Air Striker Quad Vent on 3 very similar engines once I get some more wrenching time in.
Thank you Nathan for all of your work in developing a new option for our cult-status KDX200/220 bikes! It's great to see these bikes till well supported after all these years, 40 years after the first KIPS power valve models came out, 37 years after the first water cooled model came out, with the water cooled '89-'06 200/220 STILL receiving a significant amount of attention, and still remaining a viable choice of woods bike and even woods racer.
I'm quite thankful for this community and for the successes of the KDX over the years that have cemented it's place in history quite well.
SpruceItUp
I can't wait to get my hands on mine. It'll probably get me to whip out the Lectron Pro Series as well to get it all dialed in and compare them apples to apples. I'm very glad you guys had the E series in mind as well when working on this carb. I can't see myself without my KDX nowadays, it's such a great bike.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
