Lower headlight bracket
JH013
Country: Usa
Has thanked: 6 times
Post by JH013 »
New to the forum. Just got a 2002 KX 220. Love it. I also have a 98KX 250 and a 2003 Suzuki quad sport Z 400. Previously owned 1981 KX 80, 2000 KX 250, 2004 KX 500. I’m in need of the lower headlight bracket. P/N 11048-1089. I’ve searched throughout this forum with no lock and the same on the Internet and eBay. Any help would be much appreciated. Thanks.
Re: Lower headlight bracket
Welcome aboard. Good luck on the part hunting.
JimmyB
Been thanked: 14 times
Post by JimmyB »
Hello and welcome, hopefully someone has one kicking around or this might be a option, beat to hell headlight cover and some extra parts, low ball a offer..
https://www.ebay.com/itm/198176721754?_ ... R9iJwa6cZw
Wouldn't be too hard to make one up out of some thin flat bar, 1 piece across for the headlight cover with a 90 deg bend at each end and a couple 90 deg L brackets with a twist from that bar to the triples, weld, bolt or rivet together.
02 KDX220
Has thanked: 309 times
Been thanked: 144 times
At some point a year ago or so, someone on one of the KDX Facebook groups had a batch of these reproduced. I wish I could tell you the name but I can't. You could try searching that part number of it further using the forums search tab on Google search results page.
Edit - Phil Johnson, he had five left almost a year ago, probably sold out now though....
I believe that post is not showing because it's a private group and you must be a member to see it.
This group:
https://www.facebook.com/groups/KawaskiKdxLovers
JH013
Country: Usa
Post by JH013 »
Much appreciated!! I will join that group and see if they have any.
Has thanked: 5 times
If you’re tired of dealing with heavy, easy to twist steel brackets and lost screws I suggest using the modern solution - Acerbis black rubber straps. They’re generally easy to find, inexpensive and durable. Bonus if you smack a tree they allow the mask to move enough so that it doesn’t break every time. All the modern headlight wearing dirt bikes use these nowadays.
MoonStomper wrote: 09:40 am Mar 20 2026 If you’re tired of dealing with heavy, easy to twist steel brackets and lost screws I suggest using the modern solution - Acerbis black rubber straps. They’re generally easy to find, inexpensive and durable. Bonus if you smack a tree they allow the mask to move enough so that it doesn’t break every time. All the modern headlight wearing dirt bikes use these nowadays.
Thanks for the tips!
I had what I believe were some UFO straps, but they deteriorated. Then my second KDX came with what I later learned were 97-07 KLX 300 headlights straps, which I like quite a lot, however they are no longer available new last I checked, or at least they were terribly expensive when I did find them at maybe $25 a piece. Eventually I found a used set of four, for a fair price.
Acerbis headlight straps sound like a great option!
I think you can find some generic version on eBay and Amazon, pretty cheap, but similar quality to the name brand best I can tell.
