Kdx headgasket thickness
JZ05220r
- Has thanked: 3 times
- Been thanked: 6 times
I’m curious what the stock head gasket thickness is for a kdx220. I am going to try to have a copper headgasket cut for my 220. Thanks
kdxdazz
- Country: thailand
- Been thanked: 41 times
Re: Kdx headgasket thickness
surprised nobody was able to reply to this given a few posts ago was about squish band and compression, from memory its 0.20mm
but before making any head gaskets i would check your squish clearance first then you can customize it
pumpguy
- Been thanked: 2 times
You may want to check if the gasket you get has been annealed. Being rolled to that thickness, the copper could have become work hardened. If so, it won't deform to comply with the joint faces and seal the joint.
You may be able to anneal it yourself by heating to a glowing red color, but I'd be concerned about warpage.
Contrary to common belief and often published advice, quenching in water or just letting the copper air cool has no effect on the annealing process. Its the heating that does the annealing.
JZ05220r
I think a lot of the guys on here have heard enough from me, and I wouldn’t blame ‘em. Just took my 1991 200 for a ride and it was awesome, just having such bad luck with this 220. Thanks for the infokdxdazz wrote: 03:15 pm Sep 14 2023 surprised nobody was able to reply to this given a few posts ago was about squish band and compression, from memory its 0.20mm
JZ05220r
Thanks for the info. I’ll see if they can make it for me, and make sure to ask if it is annealed.pumpguy wrote: 04:15 pm Sep 14 2023 You may want to check if the gasket you get has been annealed. Being rolled to that thickness, the copper could have become work hardened. If so, it won't deform to comply with the joint faces and seal the joint.
- Has thanked: 309 times
- Been thanked: 144 times
I came to the KDXR search function looking for the same info, being too lazy to go out to the shop and find an OEM gasket and measure it's UNcompressed thickness...
https://www.cometic.com/products/C7298
Cometic's 70.00mm KDX220 head gasket is stated to be 0.254mm or 0.010" thickness, rubber coated stainless steel (Multi-Layer Steel shim pack "MLS" gasket?) head gasket composition. They still list a 73.0mm bore composite head gasket (for the NLA steel sleeved 240cc big bore kits) even, as most everything that's not a frequent seller is made to order from Cometic.
Still curious as to the OEM head gasket thickness, if it's the same.
kdxdazz
- Country: thailand
OEM head gasket thickness with the silver coating removedChuck78 wrote: 02:30 pm Feb 08 2025 I came to the KDXR search function looking for the same info, being too lazy to go out to the shop and find an OEM gasket and measure it's UNcompressed thickness...
- IMG_20250209_171710.jpg (1.74 MiB) Viewed 8710 times
Oh wow, I'm surprised to see you with inch sized tools, also surprised by the thickness.
After reading a lot of positive reviews here on the forums about Cometic gaskets who are based out of my home state here in Ohio, USA, I will probably exclusively by their top and gasket kits with their viton-coated stainless steel gaskets, as I think that will definitely be as good or better than OEM and seal coolant in much better. It says rubber coated on the website but I am assuming that is Viton.
kdxdazz
- Country: thailand
Lol. I collect vintage micrometers so they are all in inches, I have 15 in my collection, Starrett being the highest value,Chuck78 wrote: 11:39 am Feb 09 2025 Oh wow, I'm surprised to see you with inch sized tools, also surprised by the thickness.
the OEM head gasket has a silver coating then on op of that there is a sticky coating, almost like wet silicone, I've reused this one many times by scrubbing it clean then using the lightest smear of three bond 1211 which is designed for head gasket use
Interesting, I did not know that 1211 was acceptable for use on head gaskets
