92 KDX200 OEM Piston Rings
SpruceItUp
Has thanked: 131 times
Been thanked: 59 times
Re: 92 KDX200 OEM Piston Rings
Post by SpruceItUp »
Molly's 70 wrote: 03:01 am Sep 07 2024 Take your piston with you to the machine shop also.
Will do. Thank you guys
'92 KDX200
'25 CRF300L Rally
'05 CR125R
SpruceItUp
Hey guys! Got my cylinder back (guy said it was runnable but i got it replated anyways) and am doing a leak down test like I always do when I put my bikes back together.
I'm getting a leak out of the KIPS side cover, there's a picture down below. I know there is a hole in here that goes straight through to the power valves but I figured the paper seal I have would seal it if it needed sealing (I don't know why it goes through to the valves in the first place). Is there an o-ring that goes in there that I cannot seem to find?
I also noticed that when I put the valves in the open position (operating valve all the way out) it barely leaks. (it went down 1 psi over 5 minutes). Which might tell me my crank seals need replaced? Or it may still be leaking through that hole, which may make sense because it is only sealing through metal-metal contact would be my guess.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
SpruceItUp
Update- I just came back down to the garage again because I was stupid and didnt test it.
I pulled the operating rod all the way out and sprayed soapy water on it, and it is still leaking, just not as badly- confirming that my crank seals are likely good.
I just didn't spray water on it the first time with the operating rod all the way out.
Figured I'd tell you guys that.
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Has thanked: 184 times
I would not worry about it leaking out the KIPS cover. Here is a picture of one from Indonesia. My 2005 KX250 has a vent / drain hose on it. I think my YZ250 does also. They leak, and one must put a paper towel "diaper" on them to keep it from dripping on the floor when on the stand.
SpruceItUp
Good to know. So it shouldn't cause a lean condition then? Thanks!
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Nah, may only cause a "leak condition". :-)
It gets pretty nasty under there.
SpruceItUp
KDXGarage wrote: 05:56 pm Sep 12 2024 Nah, may only cause a "leak condition". :-)
Fair enough haha. Yeah mine was pretty disgusting when I first took it off 😂
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Congratulations on getting it all going again.
SpruceItUp
KDXGarage wrote: 06:16 pm Sep 12 2024 Congratulations on getting it all going again.
Thanks! Still have a little while until first start. I've been meaning to strip down the frame, put some primer on and paint it, as well as the linkage and swingarm bearings need replaced. I have all the parts I've just been pretty lazy recently haha. Plus I sweat my ass off in the garage because of the humidity but I'll get there!
'92 KDX200
'25 CRF300L Rally
'05 CR125R
Yeah, I am in north Alabama. It was super cloudy and only 75 today, about to catch a lot of rain from the storm. It is tough to get out in the heat and humidity. Fall weather will be here soon.
SpruceItUp
KDXGarage wrote: 06:39 pm Sep 12 2024 Yeah, I am in north Alabama. It was super cloudy and only 75 today, about to catch a lot of rain from the storm. It is tough to get out in the heat and humidity. Fall weather will be here soon.
Oh man! I bet there's a lot of great riding up there. It's been raining a lot here in Florida, (but pretty much always does until the fall haha). Hopefully I'll only be here for a couple more years. The riding down here isn't amazing but I work with it lol. I went up to the blue ridge mountains this summer and man was the riding amazing.
I ended up going riding in Ohio this summer as well and the place I went to was gnarly as all hell! It was awesome, but man was it hard on ya. I ended up knocking myself out on a hill climb 😂 Hopefully I can better my enduro skills once I move from here.
Again, thanks for your help through this. It's greatly appreciated!
'92 KDX200
'25 CRF300L Rally
'05 CR125R
