Bottom end parts
Joeymf
Bottom end parts
Post by Joeymf »
Does anybody know where these extra peices go it fell out after taking out my gears I’m guessing the metal washer goes on the gear I put on here and I have a left over rubber ring and I already have one on the gears where does the other one go thank you
Joeymf
Re: Bottom end parts
Post by Joeymf »
Does the second ruber ring go on this side bc theirs 2 and both fell off this thing
Did you not take pictures as you were disassembling it?
Do you have a service manual?
Have you looked at the parts diagrams?
Joeymf
Post by Joeymf »
Yes I look in the manual before coming here it’s just one rubber ring and it fell off while dissembling and also I take pictures
Joeymf
Post by Joeymf »
Oh dang ok I see the rubber ring goes in the same spot the other one does thank you
you're welcome
those diagrams come in handy
Has thanked: 43 times
Been thanked: 110 times
Joey, the wide washer in your photo #3 is part number 92022 in the exploded diagram above. The diagram identifies the shaft that this wide washer goes onto as part number 13127.
Joeymf
Post by Joeymf »
Yes I see thank you guys
