Adjustable CDI for KDX 200 and 220- Interested?
Octo777
Post by Octo777 »
So just received the CDI. Just want to confirm I have this correct. With this two switches the 0 being the top the left is the low-mid and the right switch is the mid-high. Also is read in an earlier post SS109 you have you’d both set on the 3 position
Been thanked: 55 times
Yes, top left is low to mid advance and right is mid to high retard. I can't remember sure what I ended up on settings wise. I'll get back to you tomorrow on that.
Has thanked: 311 times
Been thanked: 144 times
@ SS109, have you cleared out some of your projects to the point where you can make another batch of these? Myself and my friend want one, 2 for me actually, and perhaps 2 other KDX buddies...
I'd even fund you getting the circuit boards ordered and even the components if it'd help expedite things...
Ive tested my Jaguar ignition and love it, vut have been afraid to run it full time until I get some electrical potting epoxy. I'll fill it up to his adjustable switches, and then encase those in silicone sealant in case I ever change the settings. The first switch of his just shifts the curve, the second switch dials in some more retard on the higher revs for better top end performance and extended RPM range. I'd always want the performance range, and if switching to an aftermarket ignition stator that would accidentally advance the timing more (Jaguar's purpose for the 1st switch) I don't see why you wouldn't just rotate the stator plate a slight but clockwise to compensate, vs flipping a switch.
Thanks!
Chuck78 wrote: 12:03 am Oct 18 2022 Hey MoonStomper I'm still wanting to try that adjustable CDI out.
If somebody else wanted it more badly, I could wait until the next revision as I would like something with a little less kick at the bottom but still maximum power up top, but I don't want to miss out on a chance to get one.
I'm really really regretting this call now!!!
Does anyone have one they'd sell for their full purchase price including shipping????
I also noticed that mow RM Stator and Race Tech Electrics are selling an "HP PeakRPM" aftermarket CDI replacement.
They advertise it as a replacement for the stock unit, but with higher performance connotations.
When I inquired asking if they had a timing curve vs RPM chart to share, they advised that it is like a stock CDI, but "with the rev limiter removed." Seeing as how there is no rev limiter, this wording seemed to somewhat contradict their continuation of that statement, saying "it will allow you to obtain up to 1000 RPM over OEM equipment."
Jaguar's ignition timing comparison graphs show his curve advancing about 250rpm earlier than stock, and reving out about 1500rpm higher than stock... That's awesome 👍
This PeakRPM CDI gains about 1000rpk on the top if it functions as advertised, so for $49.00, that's not bad at all...BUT...an SS109 Wild Azz Racing CDI or Jaguar KDX Performance CDI would obviously be way better!
Also curious as to what they were benchmarking off of, because according to jaguar, he uses 5% tolerance electronic components for a lot tighter tolerances and more uniform performance out of multiple CDI's in his batch, whereas OEM only used 10% tolerance, which can lead to two different stock bikes performing quite differently with everything visibly set the exact same due to the tolerances and variances in the electronics components in the CDI having different values on opposite ends of the 10% tolerances. So I wonder if they just tested one random CDI and design the curve off of that, potentially allowing the one sole stock testing unit to be on the milder side of the 10% variances?
Honestly, I haven't had enough time to really dig in to the changes that I would like to make yet. Well, unless you count the time riding and keeping my Youtube channel growing but I don't want to cut back on those at the moment. I will try to start digging in to it and see if I can get it sorted.
Trackdog
Post by Trackdog »
Maybe I am no fully understanding this but perhaps someone can help with something.
OEM
IGNITER
21119-1432
$532.69 x 1
Aftermarket
PeakRPM CDI Box for Kawasaki KDX 200 1995-2006 | KDX 220 R 1997-2005 | OEM Repl.# 21119-1432 $49.00
Same part right?
Slight difference in price.....
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
The aftermarket unit will replace the existing OEM & is an absolute no-brainer versus buying a brand new OEM unit at $500, and allegedly the aftermarket RM Stator version has a 1000 RPM broader power curve. Same application, slightly revised part for better performance.
I was looking for one of the hand built custom ignitions that has a more broad power curve than even this aftermarket $49 CDI. Well worth it for those of us who are trying to get the maximum performance out of our machines in every department possible. I don't care if I have $5,000 into my bike, it will still be way cheaper than buying a brand new Beta 200RR Race or 250RR Race Edition, and SIGNIFICANTLY cheaper than buying a brand new Austrian bike.
Trackdog
Post by Trackdog »
So I can't get the befits of a new Beta 200 out of my head!
BUT it is reassuring to the KDX is still alive and well. It's at the hare scrambles where I am still seeing the mean green machine.
And it is just awesome there is a site like this dedicated to this iconic bike.
And I also have invested a lot of time and money into mine, but I just want a good running reliable bike. The mods have been gradual so I can be competitive with the orange bikes. As I get better, so does my bike.
I am bought the RM Stator unit. Thanks Chuck. IO would not have known this existed.
Problem I have to ride the trails in New Hampshire, you must run an OEM exhaust. It's not a decibel thing which IMO it should be.
Hope this doesn't take the thread off the rails.
2004 KX 125
1986 CR 125
1994 DR350
1998 VFR
2004 DUCATI S4R
Trackdog wrote: 08:32 am Nov 22 2023 So I can't get the befits of a new Beta 200 out of my head!
I bought the RM Stator unit. Thanks Chuck. I would not have known this existed.
I spent last Saturday riding several Betas on a medium tight mildly technical woods loop. The 200RR Race Edition was an awesome machine!
Really, all of the two strokes were awesome, the XTrainer 300 was a bit tame for my tastes though, which is why people swap out the factory pipe for a factory 300RR pipe!
The 250RR was absolutely incredible and VERY FAST with only a slight feel of weight gain via the bike's handling, over the 200 RR Race Edition. I did notice the 250 RR felt significantly longer than the 200. This would make it a better hill climber without looping, but the 200 better in the tight woods. It's a compromise either way, but as is everything.
The 300RR was a BEAST! Sooo torquey, and revs out higher than I'd expected after riding 2016, 2017, & multiple 2021 KTM/Husqvarna/Gas Gas 300's. BUT... I was definitely faster on both the 200RR Race AND the standard 250RR , vs the heavier feeling 300RR. It still wasn't excessively heavy, but I could absolutely feel the gyroscopic effect of the heavier rotating assembly resisting slightly in the flickabilty of the bike in motion.
Also, the Sachs suspension did wonderfully in the rough choppy rutted out woods course. The KYB on the Race Edition definitely felt noticeably firmer. I've heard that the base valve compression adjuster assembly in the socks shocks really benefits from an aftermarket upgrade as they don't have much of a linear adjustment curve. People rip them out of KYB, Showa, and WP shocks as well and replace them with aftermarket for a wider range of adjustment, so this isn't really anything too terribly different.
Please test that HP PeakRPM ignition back to back with your existing stock ignition and let me know how it goes. I'll probably order one to test it out myself out of curiosity. I certainly hope their claims of 1,000 RPM higher rev out are accurate.
All that said, a broadened power band through ignition timing, suspension upgrades, machined cylinder head for tighter squish band clearance, aftermarket pipe, & proper jetting all make the KDX still quite a viable machine. So much so that I'm about to drop a ludicrous amount of money from my recent overtime paychecks to shave hopefully around 12 lb off of the bike in addition to I'm guessing five or six pounds saved from swapping the factory exhaust out.
My advice to you would be to run an FMF pipe with a black ceramic coating applied to it, and a pipe protector covering the logo on it! Looks very much like OEM... The pipes make a significant difference in the performance.
Or cut open the stock chamber, remove the inner lining which is a second layer of metal, and weld it back together. This will give it a little extra internal volume and boost performance a bit more akin to the FMF Gnarly Desert pipe
Chopperpilot
Post by Chopperpilot »
Reviving an old thread, but wanted to show interest if you do start making these again.
Same of course!
I'd buy two of them and even pre-pay for a pre-order if any were slated to be made...
I hope you can find more time in the future to make some again!
jamiethegiraffe
Has thanked: 1 time
Post by jamiethegiraffe »
Wow just found this thread and I would also like to put my name in the hat for a SS109 CDI should he ever make another run of them. I’m racing my 220/125 hybrid and would love to have some more power and adjustability out of the engine.
I'm still interested as well, Kelly!
Kx200x
Been thanked: 14 times
Post by Kx200x »
I’d be interested in a cdi as well
Houston TX KDX
Post by Houston TX KDX »
I'm new to the site, but I too want to be on the list.
Jaguar
Country: Ecuador
Been thanked: 2 times
Post by Jaguar »
After Xmas I'll be making my Performance CDI again, so anyone who wants one please let me know. This version allows the selection of one of four settings for the hi RPM capacitor for more tunability. (but the instructions page hasn't been updated yet) www.dragonfly75.com/moto/KDXCDI.html
Houston TX KDX
Hello Mr. Jaguar, I love reading your technical writings regarding 2 strokes. I must have spent a few hours just on your writings alone (regarding Jetting, spark timing, oil and ratios, and your trials and tribulations etc) . I wanted to inquire about the cdi box you are manufacturing. I know in previous posts the issue of vibration and potting compound came up. Will you be able to add potting compound this time around (or at least will the end user be able to add their own)? This component could be a key in the longevity of the device. I went online and it seems some compounds are exothermic and could overheat the individual components within the cdi box. The 3 types of potting compounds are epoxy, urethane, and silicone.
Jaguar
Country: Ecuador
Post by Jaguar »
I do have silicone sealant made especially for electronics so I can try to seal the board and components from moisture and vibration.
I never did for the years I rode my modified KDX but it is a good idea for good longevity.
For those unfamiliar with my videos, this page has most of them listed: https://dragonfly75.com/moto/my2Tvideos.html
Kx200x
Post by Kx200x »
I ordered this cdi box from Jaguar and if your serious about your kdx it will make a significant improvement. I have a 99kx125 E series hybrid. 36.5mm pwk with homemade divider plate, boyeson reed cage, and a platinum pro circuit pipe from an h series with kx 250 silencer, 08 crf450 coil. I like riding MX and single track woods loops. I had a 2018 beta 300rr race edition as my last woods bike and you could be chugging at close to idle and when you opened the throttle fully it wouldn't hesitate. It would just pick up and go without spinning the tire unless you got on the pipe. After installing Jaguars cdi the bottom end had a substantial improvement and I noticed the same effect. I could be crawling through a tight section in second and just open the throttle full and the bike wouldn't hesitate just got moving. I also felt it helped the midrange and top end as a trail I was previously ringing it out at the top of second I was now in 3rd gear in the midrange and It pulled very well. With the switches that adjust the timing to retard it at higher rpm I noticed it definitely picked up some over rev and could hold a gear longer. Seemed to provide a stronger spark as well because when I went to shut the bike down I let off the kill switch when it would have normally shut the engine off but it started back up so now ive got to hold the kill switch down longer. If you have the newest kdx your cdi components are 20 years old. Lost of advancements have been made in electronics over the past 20 years. Definitely recommend getting one if you love your kdx you will be glad you got it.
