Greetings from Germany
Has thanked: 159 times
Been thanked: 39 times
Re: Greetings from Germany
In the USA, the 1990 outer tubes were silver colored.
You may want to try to go ahead and disassemble them. I have a set of 1991 forks that someone used PVC for a spacer I guess. A little chip was stuck in one of the shim stacks (valving) causing it to be constantly partially open. Actually, I still have a pic from 2005 that I posted back then. I will post it again, 18 years later. :cool:
I had a Coors Light MANY YEARS ago. I am just stuck on German beer for now. I want to find Augustiner, Scneidder Weise and a few others, but so far, no luck.
You never know what is in there until you disassemble it. :blink:
Laurenz_KDX200
Country: Germany
Post by Laurenz_KDX200 »
I am now done with it. Everything is working well 👍🏼👍🏼 but the valves in the bottom were so stuck that i decided to let them untouched…
Ah probably you should watch out for „Kölsch“ its typical for Cologne in western Germany and tastes great and different ☝🏼👍🏼
